Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to: Oil and filter change on the EVO X
Old Aug 3, 2009 | 05:06 PM
  #46
drf's Avatar
drf
BTW, just wanted to add that per the service manual, the torque spec for the drain bolt is 29+/-3 lb-ft.
Old Aug 4, 2009 | 03:24 PM
  #47
Dr..Evo's Avatar
Very good write up
Old Sep 15, 2009 | 06:08 AM
  #48
Methodical4u's Avatar
just changed mine again 5500 miles without putting the car on a lift... what a pita lol. At least with the AMSoil I can let it go a little bit longer.
Old Sep 15, 2009 | 06:59 AM
  #49
steelbahamut's Avatar
delete
Old Sep 17, 2009 | 05:58 AM
  #50
Laz's Avatar
Laz
Thanks!!!!!!!!!!!!
Old Jan 19, 2010 | 12:46 PM
  #51
deludedbuzz's Avatar
Hey thanks for the great writeup.
I have a question though, I got a new crush washer from the dealer with the new filter, but when I took my drain plug out it did not have one on it.
Plus the new crush washer is an unusual shape (I'm used to the plain flat type), its this double ring thing. That looks like its already on the drain plug (I checked its not the old crush washer on the drain plug, it won't come off).
Am I ok in using the crush washer, should I skip it?
Thanks!
Old Jan 19, 2010 | 03:17 PM
  #52
cool_g_83's Avatar
I just performed an oil change this weekend and yes the crush washer is semi-donut shaped. It is not simply a flat washer, its kind of a puffy ring.
I had trouble removing the old crush washer from my drain plug, but after a few taps with a screwdriver it came off.
If I were you, I'd remove the old crush washer from the drain bolt (if one is present) and use the new crush washer that came with your OEM filter. Hope this helps
Old Jan 19, 2010 | 03:58 PM
  #53
Thanks!
Duh, found the thread that indicates the crush/drain washer that comes with a new car is painted black. Found it got it off and replaced.
Old Jan 20, 2010 | 10:21 PM
  #54
pstl_pete's Avatar
Fantastic writeup! I love the pro photos of the oil filter.
Thanks for this.
Old Jan 21, 2010 | 09:19 PM
  #55
ekim1's Avatar
great write up
Old Jan 22, 2010 | 01:33 AM
  #56
henryDgreat's Avatar
so just place the car on level surface and oil will drain just fine?
Old Jan 23, 2010 | 06:54 PM
  #57
ethanhunt's Avatar
i can't seem to find 5w30 from where i'm from. does it matter if i use 5w50 instead? apparently because we have summer weather all year long, most of the local workshop don't carry 5w30 oil.
Old Feb 1, 2010 | 08:59 AM
  #58
red kryptonite's Avatar
thanks!
Old Feb 1, 2010 | 02:33 PM
  #59
gungravevn's Avatar
Say bye to the dirty black oil. Just did mine a few weeks ago running great now.
Old Feb 4, 2010 | 05:39 AM
  #60
blincoln423's Avatar
Have been hearing a lot about royal purple oil, any input/experience?
