Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
AMS EVO X O2 Eliminator 3.0" Downpipe Installation
Old Sep 3, 2012 | 07:37 PM
  #301
redhead714's Avatar
Originally Posted by itsbonestock
Do you have to put the heat shield back on the ams widemouth ? and also will it bolt up to the remaining stock exhaust pieces? just curious because i am buying a used one and wondering if i could bolt this up with the remaining stock exhaust
Not sure if you have to put the heat shield back on, but it is probably a good idea to, I did when I put my dp on. Also, it should bolt right up to the stock cat.
Old Sep 14, 2012 | 06:56 AM
  #302
Chafed Banana's Avatar
You do not reuse the downpipe heat shield. I installed the AMS downpipe on my X a few days ago with the help of a very good friend. This is a great thread. I read almost the entire thing before doing it. I bought all the recommended tools (14 mm ratcheting flex head wrench is a must, along with a 18" 3/8 ratchet extension, breaker bar and aviator snips, PB Blaster and some anti-seize compound). A pivoting head flash light was a necessary item too. For my friend and I, it was a complete success. We had no bolts seize or bust. We feused the downpipe gasket. We took everything off we could, including the waste gate and front passenger side wheel. We did it in his garage on jack stands. The nut on the downpipe everyone says was difficult getting to was not that bad. Just make sure you have short and deep 14 mm 3/8" sockets and all kinds of14 mm crescent wrenches. There were 2 bolts that were not possible for us to reach. They are the 2 bolts underneath that hold the down pipe's heat shield on. Without the heat shield completely off, it is impossible to get to the last bolt holding the downpipe on. I removed everything I could but there was no loosening the bolts holding the shield on. Not even with the 18" extension. This is where the snips came in handy. After that, I disconnected the O2 housing from the downpipe. On top there is one last bolt that blocks the DP from lifting out. It holds an L-shaped bracket in place. Its difficult to see but it has to be removed. Make sure to loosen the O2 housing's O2 sensor before disconnecting it from anything. I believe it takes a 7/8" crescent wrench. I let the car cool with a big fan pointed at it as we took it apart. We used all the PB blaster we could and went slow and it worked out. I did have a really hard time getting the O2 sensor loose and then there was the DP's heat shield and figuring out the other bracket was blocking the DP from coming off. Total time spent: 12 hours. I am very happy we were successful with this for my car. The journey was an epic one. I don't know if I could have done it without my friend. I would say for me that the results were worth it. I feel very good about having conquered this install and that the work was done by me and that I didn't have pay someone else. I know every bolt is back in and with anti-seize compound and there are no leaks. I would not ever want to do it again though. At least not a stock DP to aftermarket. Damn that heat shield.
Old Oct 14, 2012 | 09:45 AM
  #303
MadBoostedEvo's Avatar
Just installed my AMS downpipe yesterday.
Took me and my buddy about 6 hours to remove the old downpipe and install the new AMS downpipe, with a lift and a wide assorment of tools.
It took us about 2hrs to take 2 bolts off. Luckily none of my bolts snapped. Installing the new AMS downpipe is a walk in the park. It took my about 30mins to have it all bolted up and the car running.
Old Oct 18, 2012 | 12:16 AM
  #304
geoxrge_gsr's Avatar
looks like a bust to do
Old Oct 18, 2012 | 05:48 AM
  #305
You've got to really want it. You have to be fearless.
Old Oct 18, 2012 | 10:39 AM
  #306
who's in Socal that can help me install my 02 dump? haha
Old Dec 1, 2012 | 06:28 PM
  #307
X&XL's Avatar
This is a complete PITA it took me and my brother 6hrs to get the OEM downpipe off and i quit for the night after that. Never again , id rather pay next time!
Old Dec 1, 2012 | 10:14 PM
  #308
redhead714's Avatar
At least you got the hard part done! Putting the new one on is much easier
Old Dec 2, 2012 | 06:14 AM
  #309
X&XL's Avatar
What bolt is used for the one that goes in the opposite direction?
Old Dec 2, 2012 | 08:38 AM
  #310
redhead714's Avatar
Not quite sure which bolt you mean, can you take a picture?
Old Dec 2, 2012 | 10:46 AM
  #311
X&XL's Avatar
I got it! Thanks. Finished! After driving it around my butt dyno says its slower. Once my intake comes in I will get it tuned. This Thread was great help to me! Thanks all
Old Dec 2, 2012 | 07:20 PM
  #312
redhead714's Avatar
So what bolted up there, you got me curious now lol!
Old Dec 3, 2012 | 05:05 PM
  #313
X&XL's Avatar
I was talking about the bolt in the o2 housing that doesnt come out at all. I was confused a little bit. A bolt goes there
Old Dec 31, 2012 | 02:09 PM
  #314
eh69758's Avatar
does the hot side only have studs or are there bolts and nuts as well to contend with?
Old Dec 31, 2012 | 04:29 PM
  #315
redhead714's Avatar
If I remember right, there are 4 studs coming out of the turbo and one stud is in the dp and has a nut on the turbo side.
Can someone confirm this?
