Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Spring Install - Tein S.Tech
Old Jun 21, 2010 | 06:13 PM
  #46
wrxnevox's Avatar
nice write up
Old Aug 6, 2010 | 09:40 AM
  #47
duracraft's Avatar
WarmAndSCSI - Awesome! This will very handy this weekend.
Old Aug 7, 2010 | 03:41 PM
  #48
JACOB3RD's Avatar
that drop is perfect but i would perfer swifts
Old Aug 13, 2010 | 06:19 AM
  #49
ToddMcF2002's Avatar
How did the rear strut piece snap off? Can someone elaborate?
Old Aug 21, 2010 | 11:00 AM
  #50
marc-111's Avatar
nice write up! i used this as a reference on doing mine...
thanks!
Old Aug 22, 2010 | 10:37 PM
  #51
Byebyez's Avatar
Did this yesterday with Tein springs. Becareful when installing the front shocks back. Upper plate has markings one dot and five small dots on the opposite side. If you rotate the upper plate you can tell the angle changes. I think the one larger dot should be facing the outside towards the fender. I had some front end clunking noise afterwards. Then I change the plate position, noise is less frequent. But still can be heard and even felt from the steering wheel when moving from stop postion. Any ideas? Car only has 400 miles on it. Also made sure all the bolts are not loose including the center strut bolts...
Old Aug 23, 2010 | 08:22 PM
  #52
carolyny476's Avatar
Originally Posted by WarmAndSCSI
I wrote this up last night for my Mitsubishi site and I figured I post it here as well. Original thread: http://mitsubishipowered.com/evo-x-h...tech-t382.html
Decided to put the first mod on my Evo X. Some Tein S.Tech springs to get rid of the terrible factory ride height. I purchased them locally at RallySportDirect: http://www.rallysportdirect.com/shop...gs-p-3829.html. Thanks to Tanner from RSD for being a huge help as usual!
Here is a run down on the springs:
Front drop: 1.4"
Rear drop: 1.0"
Front spring rate: 4.2 kg/mm
Rear spring rate: 3.8 kg/mm
First off the drop is pretty ideal if you want to achieve even wheel gap. These springs are also geared to induce more oversteer as the rear rate increases more than the front versus stock and the rear stays higher. Both of these attributes will help the car to rotate better.
I've yet to see an Evo X spring install documented with photos, so I'll give it a shot. I was so impressed with the suspension and chassis design in comparison to my 8G Galant... I just had to take photos of everything.
Here are the service manual sections I referenced.
Front Suspension: http://mitsubishipowered.com/downloa...0003900-33.pdf
Rear Suspension: http://mitsubishipowered.com/downloa...0002200-34.pdf
Such a very amazing link!
Thanks you for the post.
Old Sep 6, 2010 | 07:14 PM
  #53
leenco12's Avatar
Originally Posted by Spy007
I think its symetrical... but to be on the safe side without being a mechanical engineer.... install them back the same way you took em off
I wish there were guinea pigs who've done this and already know how much lowering springs affect the stock shocks.
Old Oct 9, 2010 | 06:28 PM
  #54
I'm tacking this soon with hand tools on my X and I ran across this amazingly comprehensive how to. Its for the previous gen but it is really the same thing.
http://www.evomoto.com/tech_info.php..._12&tech_id=22
Old Nov 10, 2010 | 11:06 PM
  #55
dericchan1's Avatar
Very nice write-up. Thank you.
Old Dec 5, 2010 | 07:15 PM
  #56
wrxnevox's Avatar
do you have to cut the bump stop at all
Old Jan 8, 2011 | 03:03 PM
  #57
F_N_G76542's Avatar
very nice write up.. i just installed the same s-tech today and it went very smooth.. now for them to settle.... oh and i didnt cut my bumpstops either and i havent had any issues yet.. but like i said i just finished lol took it around the block and that was it
Old Jan 16, 2011 | 09:26 PM
  #58
ZLAYER's Avatar
I used this for my prokit install, and it went smoothly for the most part. The only problem I ran across was when trying to torque down the center bolts for the fronts. When using the torque wrench, I couldn't get it where I wanted it without the top plate spinning around to the wrong direction. I tried with strut assembly installed and uninstalled. So I just used the impact gun to get it good n snug then installed it.
Old Jan 17, 2011 | 02:58 PM
  #59
wrxnevox's Avatar
i use this too install my tanabe gf210
Old Jan 24, 2011 | 06:45 PM
  #60
jkc213's Avatar
Nice write-up, use this with my H&R..
Quick question: cause after the install and alignment I notice the FL and FR is not even..
Is the 2 camber bolt can cause this, I remember I put the FL(camber) bolt on the ryt way but FR I don't remember and its the FR is higher..
Any input??
