How does MR deserve a $4500 over EVO??
Old Dec 9, 2004 | 11:56 PM
  #121
EFIxMR's Avatar
*news flash* the MR may have a 7000 redline, but that is not where the fuel cut is.
now i know why racecar engineers get so frustrated w/ drivers.
Old Dec 10, 2004 | 01:42 AM
  #122
Space Monkey's Avatar
It Doesn't!!!!!
Old Dec 10, 2004 | 02:14 AM
  #123
EFIxMR's Avatar
Gearbox:-
Tyre:-
Top Gear gives 23.711 MPH/1000 RPM and a top speed of 180.203 MPH at 7600 RPM
Engine speeds in top gear:-
30 MPH = 1265 RPM 40 MPH = 1687 RPM 50 MPH = 2109 RPM 60 MPH = 2530 RPM
70 MPH = 2952 RPM 80 MPH = 3374 RPM 90 MPH = 3796 RPM 100 MPH = 4217 RPM
Top Speed in 1 gear = 42.929 MPH
And changes into 2 gear at 5079 RPM dropping 2521 RPM
Top Speed in 2 gear = 64.239 MPH
And changes into 3 gear at 5606 RPM dropping 1994 RPM
Top Speed in 3 gear = 87.086 MPH
And changes into 4 gear at 5830 RPM dropping 1770 RPM
Top Speed in 4 gear = 113.528 MPH
And changes into 5 gear at 5997 RPM dropping 1603 RPM
Top Speed in 5 gear = 143.872 MPH
And changes into 6 gear at 6068 RPM dropping 1532 RPM
Top Speed in 6 gear = 180.203 MPH
CASE CLOSED!
Also, on your Motor Trend example... The Vette has a much different powerband than an EVO. That's how it gets away with those gear ratios. The EVO is a heavy car powered by a 4 cylinder engine with a turbocharger where a tighter tranny (within reason) is beneficial. One of the biggest performance downfalls of a tightly spaced tranny is decreased top speed, but this is negated in the MR with the extra 6th gear.
Old Dec 10, 2004 | 10:11 AM
  #124
EVO Neil's Avatar
Originally Posted by nj1266
Then why are you posting if your doen with this converstion? It is really sad that you do not drive your own car in competition and you come here bragging about its accomplishments.
He wasn't bragging about his MR's accomplishments, he was bragging about how well a stock MR did. You are reading what you want and not what he posted.
You have yet to tell us if you drove the MR at all at Streets during the shootout and if you did what was your time? Not on the track it isn't. The RS is better on the track than the MR. On tracks like ButtonWillow and WSIR that have longer straights than Streets you will need to shift more and will be slower as the MT people found with the Porsche (see my post above).
Sorry but I disagree. At Streets, the track in question, you do not have to shift into fifth and if you know anything about Evo's then you would know that the first four gears are almost identical between the MR, RS, and VIII. So at Streets none of what you are saying about shifting matters. The shootout did not take place on another track, it took place at Streets, so any discussions about other tracks are invalid at this point, because they were not the tracks used this time. We only have numbers from this time!
It is also a fact that my car cost way less than the MR to build. These cars can be had for 5K. Add 15K to turn it into a race car and you have a 20K car that is only a fraction of a second slower than your MR. Considering that the MR is a 35K car, I still have 15K in my pocket that I can do with as I please.
Maybe so, but you'll never recoop the money you've invested in your wonderful Sentra, while an MR owner still has a vehicle valued at close to what he or she paid. Jeez, anybody can build anything to be fast and for cheap. I could build a Fiesta that would beat up on your Sentra and for less money, but then I'd have an expensive money hole and not a car that is enjoyable to drive on the street or that will maintain some measure of value. I'm not knocking on your Sentra either, but your arguement is pointless. We like Evo's, you like Sentra's, and the bottom line is who cares.
Here you go with your name calling again. I am calling you out becuse I know that you will NOT accept the challenge. I know that you cannot drive otherwise you would not have outsourced the driving to Frank Lin who can drive.
So what is your role? To brag about how someone else pulled a 1:29.xx in your car and tell people that they do not know how to drive when they tell you a fact that a 6 speed hand shifted gear box will slow you down. A fact that a lot of racers agree upon.
More insults, thanks. I find it odd that Frank did not shift into 5th given that the maximum speed in 4th is 105 mph. If my Sentra can hit 105 mph on the front straights on Streets, then surely the MR will go faster than that and it should require a shift into 5th.
Dude, you seriously need to get over yourself.
Old Dec 10, 2004 | 10:12 AM
  #125
EVO Neil's Avatar
I have the quickest lap record on Streets of Willow in an SE-R. My best running Kumho tires was 1:31.95. My best running Hoosiers is 1:30.93.
I was not at that shootout. I could not make it due to work schedule.
I also hold the quickest lap time for Big Willow in an NA SE-R with Toyo RA1s at 1:36.255 and with Hossiers at 1:36.099
I also hold the quickest lap time in an NA SE-R at ButtonWillow running CW with the Bus Stop and the Sweeper on Toyos pulling a 2:06.495 and CW with the Bus Stop and Star Mazda @ 2:12.314 (Hoosiers) and 2:13.442 (Toyos)
I bet that I can beat YOUR time in a stock EVO MR with my ****box SE-R. But You MUST drive the car and not someone else. I want to compete against you; my ****box with my lousy driving against your superior MR with your impressive driving skills. What say you?
GET OVER YOURSELF!!!!!That's what I say.
Old Dec 10, 2004 | 10:21 AM
  #126
nj1266's Avatar
Originally Posted by EFIxMR
Gearbox:-
Tyre:-
Is the cut off at 7600 rpm. From my calculations that is the number that you are using. If this is the case, then why do tuners like Vinshu raise the redline to 7500 rpm? Unless this is only specific to the 05 MR!!!
Does this higher cut-off also apply to the 05 GSR/RS? I find it hard to believe that Mitsu gave the MR this higher cut-off but did not do the same to the 05 GSR/RS!!!
I also find it hard to believe that no one else in these forums has reported a cut-off of 7600 rpm for the EVO MR.
I am going to make the assumption that this higher cut-off also applies to the 05 GSR/RS. In this case the 05 GSR/RS will have a higher speed in 4th gear making it even better on fast tracks like Big Willow and Cal speedway than the MR. By the numbers the 05 RS will do:
05 RS/GSR-------------05 MR
1st=43.2 mph---------42.9 mph
2nd=64.8 mph--------64.2 mph
3rd=89.9 mph---------87.0 mph
4th=122.6 mph--------113.5 mph
These numbers for the RS/GSR are still better than the number for the MR. I would love it if I do not have to shift into fifth at WSIR (Big Willow) in the 05 RS especially on the back straights at the end of eight and going into turn nine. That 5th to 4th shift really kills your speed. Turn nine is essential for good lap times at WSIR. As you know, the turn before the longest straights is the most important turn for fast lap times. Turn nine at WSIR is key to getting a quick lap on that track.
I hope you are right and the cut-off is indeed at 7600 rpm, but I really have my doubts.
Old Dec 10, 2004 | 10:24 AM
  #127
nj1266's Avatar
Originally Posted by Space Monkey
It Doesn't!!!!!
That is what I thought. Me thinks that EFIxMR is making things up
Old Dec 10, 2004 | 10:51 AM
  #128
nj1266's Avatar
That maybe the case, but he still does not have the right to tell people that they do not know how to drive when they point to him the obvious: Extra shifts on the track will slow your lap times. Oddly enough, that is the same thing you guys found out in the latest test at WSIR between the 911 and the C6 Vette. That was my main point all along and that is why the 05 RS is a better track car than the MR on ANY track.
Disagree all you want. I still have not seen any MR owner tell us what max speed they hit on the front straight of Streets. Unless the MR have a cutoff point of 7600 rpm, then the max speed in 4th is around 105 mph. That is the consensus on these boards. If you cannot hit 105 mph in the MR on the fornt straights of Streets, then something is wrong. Since you guys have tested the MR with electronic equipment, then plese tell us what is the max speed in 4th gear in the MR. That will solve the problem right there.
You are talking about value for a I do not know whether to laugh or to cry. EFI wanted to show what a great track car the MR was. If it is a TRACK car that he wants, then I can build him a track car that can kick the MR's *** for a fraction of the cost. The Sentra is NOT a money hole. It has a damned BULLET proof engine. With nearly 2800 track miles this season, I have only spent $250 on items that have broken on the car. The rest of the cost is part of the wear and tear of racing like tires, brake pads.
I LOVE the EVO, but I do not think the MR is worth the 7K extra over the RS. Hell I am getting an 05 RS next year. Read the title "is the EVO MR worth it." It is NOT for someone who wants to track their car. And let me repeat that EFI was bragging about the MR TRACK times and NOT its creature comfort.
This is coming from a guy who thinks that MT testing is the best thing since sliced bread. You guys did it again. You could not even pull sub 1:39 track times in either the C6 Vette or the 911. The record continues to pile up. First it was the Gallardo and the V8 Focus, then it was the MR and the STI and now it is the C6 Vette and 911. What next!!! A 1:39 second lap time in an Enzo
Old Dec 10, 2004 | 11:22 AM
  #129
EVO Neil's Avatar
Correct me if I am wrong, but I've NEVER, EVER bragged about my driving skills. Also correct me again if I am wrong, but we test stock, production vehicles on street tires with street tire pressures to give our readers a taste of what a stock version of the vehicle can do. Now seriously am I supposed to be offended because you got a non-stock, slick tired Sentra to run quicker laps at Streets. Seriously get over yourself and your driving skills. I'd put our two test drivers against you any time. Let's see how quickly you can adjust to driving something other then your Sentra. In case you didn't know, we have to be quick in every vehicle we drive and not just one particular make and model. Some days you jump from Kia's to Ferrari's and back into Honda's and you have to be quick in all of them and without any practice.
Old Dec 10, 2004 | 11:43 AM
  #130
EVO Neil's Avatar
Every one of those vehicle you mentioned above got five full laps at Streets - total. One warm up, three hot laps and one cool down lap, that's it! No practice, no hour session to learn the vehicle and it's handling characteristics, five laps. I'd like to see you do that in five laps. The rest of the day is spent doing photography or video for TV.
How many laps in your Sentra have you done at Streets? I'm guessing it's a little more than five...
Old Dec 10, 2004 | 11:44 AM
  #131
EFIxMR's Avatar
thanks for making this so easy.
https://www.evolutionm.net/forums/sh...ht=rev+limiter
Foordoor wrote,
The stock rev limiter kicks in at 7,500 RPM (+ or - 100) and is a fuel shutoff style limiter. Much less harsh than an ignition shutoff style limiter.
ALfriedesq wrote,
There IS a rev limiter that kicks in at exactly 7606 rpms
ALL evos have it
My Stage REV Dyno Flash can change it to any RPMS you want - we recomend 7800 max on stock engine - that give you more mph in 4th through the 1/4 mile
The base Stage Rev is going down in price to $79.99 just as soon as my web man posts it up on my page
MalibuJack (EVOM GURU TITLE) wrote,
Are you sure? Mine definitely kicks in around 7600rpm.. when you hit it, you KNOW.. if you downshift its possible for the engine to go over the limit, but that has nothing to do with the rev limiter.. I don't abuse my car so I can't really say that I've payed much attention to it or attempted to see what it is intentionally..
EVO8power wrote,
mine cuts off at 7600
webguy330i wrote,
Folks it's as simple as mechanical gauge accuracy. Not exactly new news in the world of tachometers. Some will see fuel cut (same as rev limiter as posted above) at 7200, some at 8000, but most will see it around 7500-7600.
NYEVO8 wrote,
i am almost sure mine cuts at about 7600 rpm, too.
EVO11V wrote,
the stock rev limits are exactly 7600ish I've tryed it before i got my dynoflash and made it 7800. unless like jack said your and idiot and downshift when your rpms are high, but thats just the engine running fast nothing to do with limiting.
You are also making a huge technical assumption about gearing. Maybe I was being too technical for you in my previous post, but basically every car is different. Your huge generalization that more shifting means slower needs to be applied on a case by case basis.
I can show you datalogs @ 200 times per sec of how fast a driver can shift, I assure you that they are fractions of a second. Although that will initially slow you down, this is not a lose / lose situation. What you gain is torque multiplication, which equals more acceleration.
If your generalization was correct then all cars, regardless of their intended purpose would have a 1 speed tranny. But at the same time having a 100 speed tranny is equally illogical.
That's why gearing must be reviewed under a case by case basis. And it is obvious that the Mitsubishi engineers sat down and created a gearing spread for increased performance.
You keep referencing the STi 6 speed, but guess what the STi is not an EVO MR. However obvious that is, you don't seem to understand.
The problem here is you know jack sh*t about EVO's and are you trying to argue with me. You've never even driven an MR, you never driven an 05' RS, you didn't even know that the fuel cut isn't at 7000 rpm. And you toss out these assumptions like they are fact. Maybe you should spent less time at the racetrack, and go back to school to get an education, so you won't look like an *** when you open your mouth.
Old Dec 10, 2004 | 12:09 PM
  #132
nj1266's Avatar
Thanks for the info about the rev limiter. That really makes my day. It makes the 05 RS even a better bargain over the 05MR. Now that I nkow that I can get 122 mph in 4th gear, it is less likely that I will have to shift into 5th gear on the back straights of WSIR.
You are right I did not know about the fuel cut-off, but that does not mean I do not know "jack sh*t" about the EVO. I know a few things about the car.
I have more education than you. I was done with college back in 1994 and got my PhD from USC and now I am a professor at a college in SoCal. So do not go around making assumptions about my education because you are wrong. Just like you were wrong when you accused me of not knowing how to drive and you were wrong about shifting not slowing you down.
All things being equal, an extra upshift and down shift will slow you down. In the SE-R Cup series that I race in ALL the driver except me shift into 5th gear and back inot 4th gear on the fornt and back straights of WSIR. I do not do that and I consistently get the better track times. All the cars have 16:1 weight to power ratio, run similar suspension set-ups and all drivers are equally capable. Go read any racinbg book and you will find that what I am saying is correct. It is NOT only the time needed to shift that slows you down. It is the distraction of adding shifting to the braking and steering that slows you down.
Have you ever driven the back straights of WSIR going at 120 mph into turn 8 and having to shift from 5th to 4th and brake to set-up for turn 9? I HAVE in a Works mini-cooper S and it was distracting. I have even tried driving in 5th in my car and then downshifting to 4th on the back straights vs. staying in 4th all the way. My lap times were faster when I did not do the extra shift vs. when I did just that.
And unlike you, I admit that I was wrong and I did not use PROFANITY when debating you on the net. I guess they accept a lot of vulgar people at UCB these days
Old Dec 10, 2004 | 12:36 PM
  #133
nj1266's Avatar
Let us assume that race tires can net you 3 seconds per lap at WSIR, then the lap times for the for the 911 would be 1:37. These are not good times for a 911 on R-compound tires. And let us assume that the EVO MR on R-compound tires will reduce the times by 4 seconds, then your ace driver got worse times than Frank Lin in EFI's MR. I have jumped into a car before and did quite well thank you very much. I jumped into a Works Cooper S and recorded 130 mph on the back straights of WSIR. I felt very much at home in the car. I jumped into an STI and drove it at 10/10s. I jumped into an EVO RS and drove it better than the owner did.
Your not supposed to get offended, but you are supposed to drive these cars you are testing to their full potential. These times that you are pulling do not suggest that. Sorry.
Old Dec 10, 2004 | 12:40 PM
  #134
nj1266's Avatar
Well maybe you guys should change your testing procedures. These cars are not being represented well. Give your driver more time behind the wheel so he can do a better job than he is currently doing. Everytime I read one of your articles I am aghast at the times that you are pulling. This is clearly bad for the nameplates that you are testing.
Old Dec 10, 2004 | 01:18 PM
  #135
EFIxMR's Avatar
Thanks for making my day. It brings a smile to my face to know I've schooled a doctorate.
