dynoing '05 with ACD
Old Jan 9, 2005 | 01:57 PM
cym's Avatar
cym
guys.. can you dyno a '05 EVO with ACD on snow mode? im under the impression in "snow" mode bias is 100/00 front to rear... so basically you could go on a 2 wheel dyno then, correct? instead of mechanically converting it?
thanks!
Old Jan 9, 2005 | 02:00 PM
housedj's Avatar
it would make sense to dyno in the mode you use most so the #'s are not skewed. also the dyno plays a big difference. the most accurate dyno out there is made by Dyno Dynamics. if i could, i would put 1 in my garage.
Old Jan 10, 2005 | 10:04 AM
ru4real's Avatar
You can take a risk with snow mode, or you can just pull the e-brake.
Old Jan 10, 2005 | 02:03 PM
zaverdi's Avatar
Dude, in "snow" mode bias is 70/30 front to rear... so basically it still a 4 wheel car....
Old Jan 10, 2005 | 04:30 PM
Celm's Avatar
if u dyno the car in tarmac or snow.u will get the same number
Old Jan 10, 2005 | 04:58 PM
D1_EVO8's Avatar
i think theres a article on this in the newest car and driver mag 2/05
Old Jan 10, 2005 | 05:05 PM
ru4real's Avatar
Yes, but Car and Driver is wrong about the ACD torque split.
Old Jan 14, 2005 | 04:30 PM
zstryder's Avatar
ACD doesn't work like DCCD.
IIRC, ACD remains at a constant 50:50. It just changes the speed at which the center diff locks.
Old Jan 14, 2005 | 04:33 PM
dohcvtec's Avatar
yes, it only locks and unlocks. kinda like having a locked center diff or an open center diff.
Sayajin
Oct 3, 2015 06:40 AM
davidmr9
Aug 10, 2014 12:49 PM
Ltong
Aug 27, 2013 06:06 AM
Roen
Aug 10, 2013 05:39 AM
evo 8 ya
Jan 20, 2005 05:58 AM
