Whos not buying an X? for whatever reason
Old Jun 27, 2007 | 08:29 AM
  #106
SlateFox's Avatar
i dont have an Evo yet but once im back from this Deployoment ill be getting the VIII or IX... wont be layin my hands on a X for a while til Aftermarket companies get their hands dirty first
Old Jun 27, 2007 | 10:53 AM
  #107
EvoFlash's Avatar
I just want to see and drive it in person and go from there.
Old Jun 27, 2007 | 08:48 PM
  #108
Sky3's Avatar
I just don't like the looks of it...i really do think its a hate it/love it kind of design.
Unfortunately, i hate it.
Evo 6 is my fav design followed closely by the Evo 9.
Old Jun 28, 2007 | 05:53 PM
  #109
slicedbreadno2's Avatar
It's like what would you rather get an 03/04 cobra that can get silly power easily and are still holding their value. Or a Gt500 that is way more expensive and alot heavier? And not as awesome as the terminator IMO. Plus those terminator's(which are Iron Blocks) people are swapping in turbo's and getting some sick numbers out of them 750-800 HP level. You'd probably have a hole in an aluminum block handling that kind of pressure. I mean these High HP Evo's are boosting 50+ Psi which is just plain nuts. Also, even though the current Evo is an Iron Block, it's still lighter than the estimated weight of the Evo X's(which is estimated at 34-3500 lbs) and those will have aluminum blocks. I'd rather just keep my evo and get a bike or something.
Old Jun 28, 2007 | 06:42 PM
  #110
evil4g63's Avatar
Originally Posted by Draco-REX
That's ok, lots more people were upset when GM retired the venerable Small Block 350 in favor of the Aluminum LS1. Now look what those LS series engines are doing now!
the LS series engines still are 350 cubic inches the main difference is that the LS engines have individual coil packs for each cylinder. and i think theyre aluminium blocks but im not sure, gm didnt completely go away from the 350 they just refined it. this new evo engine is completly different in a ton of ways but i give it a year and itll be bad a$$ just like the 4g63 it just needs to prove itself and earn its keep.
Old Jun 29, 2007 | 01:36 AM
  #111
Skim003's Avatar
I hated the look of the evo X at first but it is starting to grow on me. But since it is on new platform I'll would wait couple years for them to work out the bugs. I'm not too concerned about the new 4B11 aluminum block, I just hope they keep the rawness of the evo's and not turn this into a luxury sedan.
Old Jun 29, 2007 | 02:27 AM
  #112
turtlelancer's Avatar
Explain the luxury part.. im still at awe at why people state that claim. How the f is it luxurious? if you think thats luxurious your coming from a freaking bucket. Or is it that since my friends have 335i. Lexus is350, and etc that i am not getting it? There is nothing even luxurious about that car
Old Jun 29, 2007 | 02:43 AM
  #113
tolga900's Avatar
evo make the peak with 9 after this ı wont use evo ı wiil buy new m3 next year.
Old Jun 29, 2007 | 03:27 AM
  #114
SRT-TO-EVO's Avatar
<-------1.Not buying one cause they're F******g ugly
2.Next car will be a luxury car
Old Jun 29, 2007 | 04:43 AM
  #115
Soon2BEVO's Avatar
I will definitely not buy one, ever.
Old Jun 29, 2007 | 10:26 AM
  #116
Draco-REX's Avatar
Actually the LS1s are 346Ci, but they still call it a 350, and all of the LS series are AL blocks. As far as a refinement, no. The LS1 was a revolution, not an evolution. The only parts in common between the LS1 and the old Smallblock 350 are a couple bolts. Absolutely everything about the engine was redesigned.
Some of the bigger points:
Symmetrical head design, rather than the odd/even mirroring of the old chevy heads.
12degree valve angle, better than the Winston Cup racing heads that were in use at the time. This allowed for airflow on par if not better than most OHC engines, but with fewer moving parts.
Composite intake, nearly eliminates heat-soak.
One coil-pack per cyl as you mentioned.
New firing order to smooth out idle.
All AL block with 6-bolt, cross-bolted mains and a deep skirt to further increase strength.
And that was just the first generation LS1, not any of the subsequent revisions or derivatives (LS6, LS7, etc). Believe me, for all the people that are reqretting the passing of the 4G63, there were TONS more for the passing of the old 350. That engine was put into almost everything and had a history MUCH longer than the 4G63. What I was saying was that everything thought the LS1 was the end of big power and versatility. They were very, very wrong. And I think the 4B11 will prove similar.
Old Jun 29, 2007 | 01:22 PM
  #117
The LSx series engine's have such a high displacement engine though 5.7 liters, It could make easy power because of how much displacement it has. Compared to the new 4B11 which will STILL be 2.0 liters. I mean you really can't push the envelope any further. If the car was receiving more displacement I could see it probably being better but it's still going to be a 2 liter. So why not just stick with an already proven 2 liter that has already reached such great success in the tuning world.
Old Jun 29, 2007 | 07:09 PM
  #118
Draco-REX's Avatar
Fuel efficiency. Lower Emissions. Both things that required by the government to improve.
Also, mitsubishi had hit the limit of power with the 4G63 while meeting the standards set for Efficiency and Emissions. Remember, manufacturers are under much stricter requirements than the end user. The 4B11 will let Mitsu meet the standards set by the government and allow for future growth.
As for the LS's displacement. So? That really has nothing to do with my point. I was comparing the *CHANGE* of the LS1 over the iron 350 to the change that's now taking place with the 4B11. My point was that the LS1 was an improvement in nearly *every* way over the old engine, and more than likely so will the 4B11.
Old Jun 29, 2007 | 11:10 PM
  #119
Normanruben's Avatar
right now, i do not like the X because it does not have that wide body that the current evos have. but i don't know, it may grow on me once it comes out. but right now, i would not trade my viii to the x.
Old Jun 30, 2007 | 05:03 AM
  #120
Jakeg97's Avatar
Originally Posted by blitzkrieg79
I don't think a base Evo will be any more expensive than the current RS. Of course adding the big stereo or navigation will add to the price but then again those things aren't available for the current Evo so it's not a fair comparison.
i think the top of the line evo 10 will break 40k and the base model being more priced around the mr version; at least 32k plus
