Idea on how to mount the ECU+ Box
Old Nov 3, 2005 | 12:14 PM
Ev0ikon's Avatar
Lightbulb Idea on how to mount the ECU+ Box
I have the box dangling behidn the glovebox for a while now and just now having some time to do somethign about it. Does anyone have any idea on how to secure this thingie?
Pictures/diagram would be much appreciated.
TIA.
Old Nov 3, 2005 | 03:01 PM
EvilDylan's Avatar
I do
mine is super special. All you see is a tiny serial port on the console. :-)
Old Nov 3, 2005 | 03:58 PM
Kronik's Avatar
Velcro is your friend
Old Nov 3, 2005 | 09:33 PM
forum04pl's Avatar
Originally Posted by EvilDylan
I do
can you post pics of your setup?
Old Nov 3, 2005 | 10:18 PM
G20's Avatar
G20
I zipped tight it behind the glove box and let the connected serial cable in the glove box ready for hookup to laptop.
Old Nov 4, 2005 | 08:01 AM
EvilDylan's Avatar
here's what i did. Its sort ofh ard to explain, but ill do my best.
first i built a patch harness that goes from the serial connector on the ECU + box and made that about 10" long.
pull the glovebox, and the access port to the ecu harness. Then pull the pin that holds the passenger side of the center console (shifter and ashtray area) i stuffed the box back there in the console, and cut out a little square hole in the console area and routed the patch harness that i made through there, and mounted the connector with a couple of screws.
i tried velcro, but it gets too hot inthe summer and the sticky wears off. Same thing with double sided tape.
I'll try to take some pics of my setup this weekend. It's a PITA to undo and redo.
Old Nov 5, 2005 | 12:54 AM
Ev0ikon's Avatar
hehehe
yer crazy Dylan.
I was thinking of just keeping my serial cable wound up in the glove box. Just need a way to secure the box :P
Old Dec 15, 2005 | 05:10 PM
Eshark's Avatar
I'm trying to install my ECU+ with patch harness tonight. How do you get all the wires above the ECU wire guard? With the patch on the ECU the bottom hangs almost to the floor. I tried folding the harness, but it feels like I'm placing a lot of stress on the ECU wires. Any help, pic, ideas would be great. Thanks.
Old Dec 15, 2005 | 10:21 PM
Eshark's Avatar
Bump
Old Dec 16, 2005 | 07:13 AM
Ev0ikon's Avatar
I have to remove the black plastic wire cover(the removable piece) and release the main cable pack from one of the zip-tie-looking hook. If that makes any sense :P
Try not to put any stress on the cable assembly. Use zip-tie to hold everything up. I will take a picture and post it here when I get home if you want.
Old Dec 16, 2005 | 12:59 PM
Eshark's Avatar
Thanks, that would be great.
Old Dec 22, 2005 | 05:44 AM
EVOLUTIONIZE's Avatar
Some pictures here.
http://www.ecuplus.com/forums/viewto...166&highlight=
evo9powerr
Jun 1, 2014 06:41 PM
mikeyboy86
May 5, 2010 11:09 AM
Schuyler
Jun 19, 2007 01:30 PM
Recon
11
Jun 1, 2007 03:59 PM
