EcuTek boost control?
Old Mar 17, 2006 | 07:37 PM
  #31
lukytry's Avatar
ecutek holds boost just fine, take a look!
https://www.evolutionm.net/forums/sh...d.php?t=190273
Old Mar 20, 2006 | 06:10 AM
  #32
joshd's Avatar
Originally Posted by Boosted Josh
I'm not sure how they hooked it up. I wasn't even aware that there are multiple ways to hook it up. haha. I think that they recommend the EBCS to people who aren't going to mess around with the boost. I have no intentions of running 100 octane and jacking the boost up.
For mods I've got a buschur turbo back, a K&N drop in, perrin EBCS, the tune, and 42 draft designs gauge panel (boost, oil, volt). The car made 323awhp and 300awtq on Topspeeds dynojet.
BTW sorry for the delayed response.
Those are great results, nice job by the TopSpeed folks. I wish there was a good tuner in the DC Area doing EcuTek flashes so I could get rid of the MBC that I hate and the 3rd party mail in flash that I have that scares me due to being too lean up top ...
Old Mar 20, 2006 | 11:42 AM
  #33
evil mechanic's Avatar
me too. i want ecutek
Old Jun 1, 2006 | 09:35 AM
  #34
MR Dan's Avatar
so....the only reason to get a MBC or EBC with the ECUtek flash is the ablility to change the boost levels accordingly with different octane fuels?? Couldn't the ECU adjust its self?
Old Jun 13, 2006 | 03:29 PM
  #35
fatbastard's Avatar
unfortunatley, not many "tuners" have grasped how the mitsubishi boost control works and what you need to change to have it work properly with a flash (this holds true for both ecutek and other reflashing tools)... a properly calibrated ecu will controll boost very well, while still allowing the factory safeties to function if something goes wrong...
Old Jun 13, 2006 | 03:34 PM
  #36
ROK EVO's Avatar
Fatbastard,
Why is Ecutek a better platform for tuning IX's in comparison to traditional (tachtom) flashes? Also, does Ecutek have control functions for the Mivec?
Old Jun 13, 2006 | 04:33 PM
  #37
fatbastard's Avatar
yes, ecutek does have the locations of the mivec maps...
essentially, all reflash tools are equal, they both modify maps that are already in the factory ecm... that said, Techtom supplies the end user ("tuners") with basic maps (ignition, fuel, boost limit), EcuTeK supplies their dealers with many more (currently ~40 maps)... this allows EcuTeK users to custom tune the ecm to better suit the end user... they also do frequent updates and offer a large library of base and stock files that many dealers find helpful for extracting more power safely from your ecu...
that said, what atually goes down is dependent on the actual person calibrating your ecu... regardless of how many maps are available, if they are not able to understand or use them properly it doesn't matter which platform is used...
Old Jun 15, 2006 | 12:58 PM
  #38
MR Dan's Avatar
one last question..... do i need to upgrade the stock fuel pump with these simple mods before i get the ecu flash??
Intake
Down pipe
High flow CAT
Catback exhaust
Old Jun 15, 2006 | 02:29 PM
  #39
ROK EVO's Avatar
MR Dan,
You don't need to upgrade your fuel pump w/ your current set-up.
Yearlongstorm
Feb 12, 2009 03:05 PM
AutoMotoSports
EvoX 'For Sale' External Engine / Power
95
Aug 19, 2008 09:59 AM
is300
24
Jul 18, 2008 03:22 PM
AutoXer
Jun 7, 2008 04:12 PM
