The stock 05 evo build has begun
Old Dec 16, 2007 | 04:53 PM
  #286
Mellon Racing's Avatar
yeah I wasn't too vocal about it because I didn't want people giving me hell for not getting there but i was thinking to myself 400 should be the minimum, 450, easy and 500 a challenge. So I'm very happy with it.
I was going to get a video today but it got dark on me...maybe I can get a shot of the speedo/boost/afr ? it's all back lit but not sure I can hold the camera...maybe just a 3rd gear pull.
Old Dec 16, 2007 | 05:32 PM
  #287
jrsimon27's Avatar
i wanna see pictures of the engine please
Old Dec 16, 2007 | 07:12 PM
  #288
here's some video I just shot, I'll get some pics tomorrow maybe, it's pitch black out right now.
http://www.racevideoforums.com/forum...ead.php?t=3147
Old Dec 16, 2007 | 07:20 PM
  #289
prostcj's Avatar
nice video
Old Dec 16, 2007 | 07:59 PM
  #290
just for you
took some pics... the exposure length is cranked up on some of them and I wasn't as steady as needed so they blurred a bit so I took a few with flash.
Old Dec 16, 2007 | 10:06 PM
  #291
Wicked E's Avatar
*Woody hitting desk*
That is all...
Old Dec 17, 2007 | 03:16 AM
  #292
jrsimon27's Avatar
thanks a lot mellon that engine looks fantastic,its good to see that you can use the stock radiator with that turbo
Old Dec 17, 2007 | 04:08 AM
  #293
I don't know if that radiator hose needed to be wrapped or not...it was a precaution, I was worried that it might melt the hose or at least heat up the coolant.
Old Dec 17, 2007 | 07:04 AM
  #294
KevinD's Avatar
Originally Posted by Mellon
well I did some minor tweaking and have it completely knock free even when rowing through the gears and it's ~ 11.3:1 to redline. The IDC's are still 110%+ so it looks like the 780cc injectors are a bit small for pump gas on this turbo. I could install my meth kit and have plenty of fuel but I that would complicate the setup and I don't feel the need for more power on the stock block right now. I could drop the timing a bit and ramp up the boost to ~ 30 if I wanted more, so I might pick up a set of 880's to get that IDC down first.
hahaha, after all this sizing injectors and your not even running the meth!? you haven't experienced a 35r until you've experienced it on meth
running two 1mm nozzles will be adding around 1000cc/min more fuel. thats basically like going from 780cc/min injectors to 1000cc/min injectors. sense you are around 110% on pump, you would have been nearly perfect with those injectors and the meth spraying.
Old Dec 17, 2007 | 07:14 AM
  #295
newbieEVO8's Avatar
Ok mellon, please close the hood on that beast.
I am so tired of looking at it.
Dang I am tired....
Old Dec 17, 2007 | 07:23 AM
  #296
yeah what a great dilemma...I thought I was going to need meth to get 500awhp on pump gas through the stock ecu/maf boy was I wrong...it was a piece of cake
1) I'll have the stock short block for a long time so I'm not looking for much more power right now.
2) I want to max it out on pump gas and re-evaluate the need for meth
so the meth kit stays boxed up for now and I just ordered some PTE 880cc to get that IDC down a bit on pump gas. I still haven't installed the 65mm tb or ported intake either
Old Dec 17, 2007 | 07:33 AM
  #297
iturregui's Avatar
Plus some of us only wanna run pump gas. So it's nice to see a freshly-installed, pump-gas-only, HTA 35R powered Evo and the results. Good job Mellon
Old Dec 17, 2007 | 07:35 AM
  #298
yep, I like to keep it simple as possible and I've met my goal without needing meth so I'm in no hurry at all to install it now. I just need to get the IDC down a bit, I don't need more power.
Old Dec 17, 2007 | 08:01 AM
  #299
zbomb's Avatar
Awesome video, Seems very quick spooling.
Thanks for all the info your putting up, Hope my setup ends up on the same level.
Old Dec 17, 2007 | 08:33 AM
  #300
yeah about 4500 is where the party starts..not bad at all.
I posted a full review here https://www.evolutionm.net/forums/sh...d.php?t=313778
