The stock 05 evo build has begun
Old Mar 3, 2008 | 03:16 PM
  #421
Liqquid's Avatar
Really though, it makes me nervous too, the close proximity to the new tubular manifold, but at the same time you gotta give it up for doing just what Chris is doing... only what is necessary for performance.... I think by now he would have found out if it was going to cause a problem, I expect coolant temps to slightly rise with more power produced, so it might be hard to tell if that is heating up the coolant b/c of that, or just from the hose being close.
Have you noticed any raise in coolant temps since installing the kit?
Old Mar 3, 2008 | 05:09 PM
  #422
wizzo 8's Avatar
Hey Chris I noticed you dont have T-clamps. Have you pressure tested your system for leaks? With that much psi I would think so. I have that same upper I/C pipe from Buschur and found it leaking with worm style clamps like you have. I recently changed them over to the t-clamp style and fixed my leaks. Im only boosting to 22psi max also. This might you.
Old Mar 4, 2008 | 07:00 AM
  #423
Mellon Racing's Avatar
as for the coolant hose, if it hasn't burned by now it's not going to, I've had the car way past 160mph in some 5th gear pulls, no issues whatsoever. It does have header wrap on it just in case.
I have pressure tested the system but not up to 30psi..maybe 20psi max. I don't like that tester fitting shooting out like a cannon. I don't like using t-bolt clamps unless I have a hose that keeps blowing off.
Old Mar 4, 2008 | 09:04 AM
  #424
Red Sox's Avatar
Man that engine bay is like pure sex.
How did your Evo do the other day?
Old Mar 4, 2008 | 09:05 AM
  #425
Red Sox's Avatar
^ Oh, hardcore pure sex... btw.
Old Mar 4, 2008 | 10:11 AM
  #426
Liqquid's Avatar
Yea, I noticed in your other forum
+1 on the flying tester, almost got owned by one of them myself last summer...
Old Mar 4, 2008 | 10:50 AM
  #427
terrible, just before the race I noticed the clutch was dragging (notchy shifting and grinding going into reverse) I managed to adjust it out and thought I was good to go but the engagement was so close to the floor board that I bogged the launch twice losing both races I had setup
Old Mar 4, 2008 | 11:29 AM
  #428
Red Sox's Avatar
In the immortal words Homer Simpson, "D'oh!"
That sucks to hear about your clutch.
Old Mar 4, 2008 | 03:30 PM
  #429
Liqquid's Avatar
lol, its ok... just give them a false sense of security.... they won't know what hit 'em next time
Old Mar 4, 2008 | 04:45 PM
  #430
wizzo 8's Avatar
So is your clutch done? Time for a rebuild?
Old Mar 4, 2008 | 05:11 PM
  #431
evovin's Avatar
If its your clutch...you can convert that it to triple.
Old Mar 5, 2008 | 05:55 AM
  #432
I don't think the clutch is done, it's doing fine now that I've adjusted it...in hind sight I think I was letting the clutch out too quick for the adjustment point and it was bogging. I need to slip the clutch and get the car rolling before going wot
Old Mar 5, 2008 | 03:48 PM
  #433
FLOW1's Avatar
That sucks Chris. But anything else new?
Old Mar 6, 2008 | 06:01 AM
  #434
not much, picked up some vacuum hose for the EBC, hope to get some time to play with it this weekend. I hit a snag with the Stealth rebuild, found the front exhaust cam had two bad lobes and rockers, I'm not sure if the rocker came loose or what. I have Dynamic Racing making a replacement cam for me so that's a 2 week delay.
Old Mar 7, 2008 | 06:22 AM
  #435
I ditched my home depot MBC for a Greddy Profec B Spec II last night and dialed it in for a peak of ~ 30.8psi but snow is coming so I'm not sure when I'll get g-tech/dll/track times yet. Hopefully this weekend.
