The stock 05 evo build has begun
Old Mar 27, 2008 | 02:19 PM
  #466
Mellon Racing's Avatar
Originally Posted by rolly1818
i plan to make only about 300-320whp on my evo, its my DD as well.. what mods would recommend?
BTW its a JDM Evo IX
with 93 octane
K&N drop in filter
boost gauge
manual boost controller @ 23psi
turbo back exhaust
and when you're done, let me tune it to extract the power, the stock tune is horrible. I have a link in my sig that explains the process and software/hardware required. I recently added a video tutorial to make it even easier.
the cams might not be necessary on your IX
Old Mar 27, 2008 | 03:57 PM
  #467
rolly1818's Avatar
Registered User
only Cams, retune, exhaust, dp, intake, headstuds, ebc
dont wanna go cams cause i want my car very streetable lol...heard cams causes some problems. the rest is fine..
i am thinking to substitute for the cams a water/meth injection kit should work?
Old Mar 27, 2008 | 05:04 PM
  #468
cams and a good tune work fine for a street car
Old Mar 28, 2008 | 03:43 AM
  #469
rolly1818's Avatar
Registered User
i do my tuning myself..how do u tune for cams..what is good to look for etc? i know i should be tuning the mivec map right?
but what else is there to look out for?
Old Mar 29, 2008 | 10:51 PM
  #470
05EvoVIII's Avatar
Originally Posted by Mellon
yep it's my daily driver.
well I had a bad weekend...out having some fun in the snow I caught a curb going about 30-40mph I'd guess. It's at a body shop right now but hasn't been inspected yet. The right rear wheel was busted, control arm etc... not sure what else, I really didn't want to look at it The good news is that nobody got hurt and I suspect the car can be fixed.
Wow thats crazy i just did the same thing a lil over a month ago to the same side n the car still isnt fixed yet becuz im waiting on parts to be shipped . There was no body damage tho. I work at a body shop so i am repairing everything myself. I got a lot of my parts off ebay from evos being parted out i saved a ton of $$$$$.......For one evo stock axle they wanted over 700 bucks from Mitsubishi..haha **** dat!
Well with that said lol i wanted to say thank you for putting this thread together bcuz i have learned a lot reading this and every time i had a question in my head i would just scroll down n there was the answer! Awesome job Mellon!!
Brandon
Old Apr 5, 2008 | 06:40 PM
  #471
FLOW1's Avatar
Anything new Chris?
Old Apr 8, 2008 | 08:25 AM
  #472
got the EVO out of the shop Friday night, installed the BR twin walbro and 1000cc injectors. I have them pretty much dialed in but let me tell you, it's very tricky tuning for that second pump coming on with boost. It makes for a pretty funky fuel map.
I'd say the tune is about 90% done, just working on some part throttle issues. I'm starting to use Logworks so I can dump everything into a table but there's a flaw where it clips the load at 220kpa so I can't see beyond that just yet. Asmodeus is helping me out with logworks since he's got lots of experience with that issue, so I'm sure I'll get it sorted out soon.
I did a few DLL pulls and I'm seeing ~ 500awhp on average via DLL, that's down about 25awhp but I have to keep in mind that when I was seeing 525awhp it was 20-30* outside and now it's in the 70* area so I'm sure that's going to have some impact.
Old Apr 8, 2008 | 04:27 PM
  #473
1320 Engineering's Avatar
must be great to have your car back... longest ive gone without driving my car is about 4 days lol
GL with the new tune mellon!
Old Apr 9, 2008 | 01:20 PM
  #474
FLOW1's Avatar
Glad your car is back and ready for more runs.
Old Apr 12, 2008 | 10:19 AM
  #475
thanks, I did a quick tune/review of the twin pump setup here:
https://www.evolutionm.net/forums/sh....php?p=5533983
Old Apr 12, 2008 | 09:14 PM
  #476
well I've been putting this off forever simply because I haven't had a reason to yet. I decided that before I do the built shorty/head/cams and pump then race gas boost levels I better secure the stock MAS screen before it gets sucked into the turbo. I picked up some general use epoxy from Advance Auto. I pulled the air filter off and ran a bead all around the outside edge of the honeycomb where it meets the MAS plastic. I noticed the honeycomb was rotated to the left a touch so I straightened that up first.
I suspected this would change the tune slightly and boy was I right. My mid trim went from 102 to 71 and I I was pig rich at WOT, into the 9's AFR. I pulled a log and saw that my peak load went from a previous high of 345 to a new high of 375! I did some cruising and dialed the mid trim back in...I ended up almost exactly 100cc higher than before to lean it back out. I wound up with the mid at 96 which is close enough. I went WOT and by mid range the AFR was slightly lean and by high rpm it was unacceptably lean. I added 2 fuel in the mid range and 4 fuel high rpm range and got my AFR back where it was.
I did a few 3rd gear pulls and 1/4 mile runs and everything is just about perfect. My laptop battery died (forgot to take my power inverter) but it just need one more adjustment and it should be spot on again.
So it seems by putting a bead around the outer edge of the honeycomb it's forcing more air through the center of the MAS where the airflow sensor resides, thus it's seeing more air than ever, an unfortunate side effect.
I may simply remove the honeycomb altogether and tune around it the way I have with my Stealth TT (almost identical ECU/MAS) but I'm hesitant to do anything that my customers wouldn't feel comfortable following. I don't want to get so far off the beaten path that I alienate my customers. It's important to me that they can look at my setup and say "that's not too complicated to clone for my own car"
I've let the boost spike up before and I hit a 380kpa limit to what the ECU can log and now with the load at 375 it's going to get real interesting when I do the shorty/head/cams. I know that by removing the honeycomb the MAS will see much much less airflow so I think I can go much further with the stock MAS than where I am currently.
Old Apr 13, 2008 | 12:24 AM
  #477
FLOW1's Avatar
Chris, glad everything worked out according to plan.
New engine bay photos to come?
Old Apr 13, 2008 | 11:09 AM
  #478
the engine bay is kind of dusty right now after sitting in the body shop for a month...been working on other things:
I finished the fuel tweaking this morning, slightly leaner across the board:
Old Apr 13, 2008 | 11:45 AM
  #479
FLOW1's Avatar
Awesome.
Old Apr 19, 2008 | 03:00 PM
  #480
GEORGE_23's Avatar
wow nice your curves looks really clean
this car must be so fun to drive huh
you have more to get if you decide to go over 8k . . . . . .
. . . . . . . are u thinking for jun cams??
i've seen great differences from hks 280 race to jun's
