The stock 05 evo build has begun
Old Feb 27, 2008 | 12:14 PM
  #391
FLOW1's Avatar
Alright, so I see you've got tons of work ahead of you. Well, keep us posted on the build.
-Chris
Old Feb 27, 2008 | 03:54 PM
  #392
evovin's Avatar
Im talking about straight 4 inch intake pipe with a reducer coupler 4 to 3 inch for the MAF? Will it affect any reading? Is this set up useless?
Originally Posted by Mellon
I have a 3" pipe from the MAS and a 3" to 4" coupler to mate to the turbo inlet
You're talking about having a 4" pipe from the turbo to a 3" coupler to mate to the MAS
I'm not sure if one is better then the other...I assume the airflow is going to be effectively restricted to 3" either way.
Old Feb 27, 2008 | 04:12 PM
  #393
Mellon Racing's Avatar
I doubt it'll be any better than what I have 3" pipe to 4" intake with 3 to 4" coupler but I don't think it would post a problem with the MAS/tuning either.
Old Feb 28, 2008 | 06:35 AM
  #394
swapped the BR deluxe fmic out and the BR race fmic in https://www.evolutionm.net/forums/sh...d.php?t=328567
Old Feb 28, 2008 | 11:29 AM
  #395
FLOW1's Avatar
What a difference the FMIC now is compared to your stock FMIC.
Old Feb 28, 2008 | 11:40 AM
  #396
yeah it really dwarfs it and it's built like a tank, it's very heavy but that's because it's built to withstand 40+psi
I suspect the stocker might become a grenade at that point
Old Feb 28, 2008 | 11:45 AM
  #397
Inprogress's Avatar
I don't know if this has already been answered or not, but are you planning on building the motor down the line Chris?
edit: wow i'm lazy, found my answer on the page before this lol
Old Feb 28, 2008 | 11:49 AM
  #398
yeah, but as I get closer to pull the trigger on the built motor I keep running into supporting mods that need to be upgraded first. Once I get the foundation right I'll order up. It should be pretty close after the injectors and fuel pump.
Old Feb 28, 2008 | 11:52 AM
  #399
FLOW1's Avatar
[QUOTE=Mellon;5343508 I suspect the stocker might become a grenade at that point [/QUOTE]
LOL
Old Feb 28, 2008 | 11:53 AM
  #400
Wicked E's Avatar
I hate to ask... but will anyways. Are you starving your wife on Ramen noodles? Does the water in the house still run?
Old Feb 28, 2008 | 11:54 AM
  #401
woah, we're not that high class...it's saltine crackers and rain water until I get that BR shorty
Old Feb 28, 2008 | 11:57 AM
  #402
Wicked E's Avatar
And candles for lighting??
I hope you built the outhouse efficiently... You can even use the stock FMIC to cool it out...
Old Feb 28, 2008 | 12:09 PM
  #403
Inprogress's Avatar
Old Feb 28, 2008 | 07:55 PM
  #404
FLOW1's Avatar
Anything new Chris
-Chris
Old Feb 28, 2008 | 08:21 PM
  #405
wizzo 8's Avatar
Anything new Chris
-Chris
Did you see he got a new I/C?
