ID2000, E85, and open loop issues
Old Oct 7, 2013 | 09:52 AM
Macaroni's Avatar
Posting this in different sections hoping to catch a snag:
Here it is short and sweet. Recently put in some id2000's, converted to e85, flashed on the base map, and starts up beautifully. Everything looks great while it's in closed loop and runs like a champ. The problem is once it gets to operating temp and switches to open loop, it just dies. Try to restart and it won't have anything to do with it. Fuel pressure is there, spark is there, sensors, timing, blah blah all that is there. I believe something is telling the injectors to stop firing once it gets to operating temperature. Let the car cool down, and it cranks right up again and it just keeps going like this. Anybody else experience this problem before?
Old Oct 7, 2013 | 10:05 AM
detroit pistins's Avatar
What's your afr when the transition occurs? and just to be sure... did you rescale your injectors after the switch?
Old Oct 7, 2013 | 10:22 AM
Macaroni's Avatar
Yes injectors are scaled properly and can't recall afr when it switches over. I want to say it goes lean. I've pulled a plug, turn the car over and no fuel went into the cylinder so that's why I'm leaning towards an open loop issue causing the injectors not to fire
Old Oct 7, 2013 | 05:09 PM
Macaroni's Avatar
Bump
Old Oct 8, 2013 | 12:15 PM
Macaroni's Avatar
Bump
Old Oct 8, 2013 | 01:19 PM
Doesn't the engine start in Open loop then switches to CL when the O2 sensor is within its heat range?.... just saying...
anyhow, can you share some more info? are you on speed density? what calibrations are you currently running? did you try enriching?
Old Oct 8, 2013 | 01:44 PM
Macaroni's Avatar
Yea I had it backwards in my op. Open loop everything is fine and dandy. Once it warms up and starts to go closed loop it dies. Yes I'm sd I'll have to check calibrations when I get home. I shouldn't have to mess with the sd calibrations they have been working just fine for the last 3 years or so
Old Oct 8, 2013 | 02:03 PM
Well they do impact ur fueling. So I wouldnt be surprised if they did.
Try this, lean out the SD RPM VE cal and see if that helps. Drop it in the first three brakepoints.
Old Oct 8, 2013 | 11:13 PM
Macaroni's Avatar
So you think it's in the base map where the problem is and not something mechanical?
Old Nov 13, 2013 | 11:28 AM
Macaroni's Avatar
Problem solved. Thanks for the help.
Old Nov 13, 2013 | 12:42 PM
what fixed it?
Old Nov 13, 2013 | 03:16 PM
Macaroni's Avatar
The car didn't like the MUT table that I flashed onto the Ecu so I put the MUT table that came with the base map back on it. Runs like a champ.
Old Nov 13, 2013 | 08:44 PM
good to know!
nor11384
Feb 12, 2016 09:33 AM
Macaroni
E85 / Ethanol
Nov 27, 2014 01:52 AM
10isace
E85 / Ethanol
Mar 20, 2013 06:31 PM
CDrinkH2O
Aug 23, 2012 10:54 PM
Mr_G
Aug 5, 2011 12:56 PM
