Reverting to stock from AEM v1
Old Nov 3, 2014 | 02:23 PM
cerevo's Avatar
A while back I got a stock ecu and MAF for my evo. My car came with the AEM EMS v1 and after some time of trying to get the start nailed down so it would reliably start when it was 20* outside, I got fed up with it and put my stock stuff back on.
We were never able to get it to even try to fire. it would crank and crank, didn't seem like the fuel pump ever primed. It worked just fine on the AEM (when it started) but wouldnt do anything on the stock ecu and MAF.
There were no boost leaks, I used the stock MAF and ECU, swapped out the stock MAP sensor.
Any ideas for other things to check on?
I want to revisit this because winter is coming and as soon as I get the control arms and timing belt changed out I want to drive it a couple times a week to work to keep it functioning but I'm not going to deal with it not starting any time I want to drive it.
Old Nov 3, 2014 | 02:48 PM
Ev0ikon's Avatar
Is the Crank angle sensor replaced with a trigger disc?
Old Nov 4, 2014 | 06:24 AM
cerevo's Avatar
Nope, stock trigger disc.
Old Nov 4, 2014 | 06:55 AM
ronaldo9's Avatar
Are your immobilizer settings set correctly for your ROM ID? Ensure you have the correct values in the map you are using.
Old Nov 4, 2014 | 08:34 AM
cerevo's Avatar
I set that to "0" since I don't have the hex for my key. I read that 0 was supposed to turn the immobilizer off.
Is there some other setting for that?
Old Nov 4, 2014 | 08:56 AM
ronaldo9's Avatar
Yes if you have the incorrect hex values the car won't start either way. If you load tephramod v7 there is a universal rom that works on all 8's IIRC. I can link you the thread if you can't find it.
Old Nov 4, 2014 | 09:51 AM
cerevo's Avatar
so this doesn't work?
The FAA bits is what I was referring to. It's been a while since I tried this so forgive my lack of vocabulary.
Old Nov 4, 2014 | 09:58 AM
ronaldo9's Avatar
https://www.evolutionm.net/forums/ec...hramod-v7.html
Pay attention to this section
Option 1 96530706 (v7) - Download | Mirror
Set Immob. HEX to 0x0040 (check to make sure your old ROM was the same)
Option 2 - Thanks to l2r99gst 96532706 (v7 + Live Map + MAF) - Download | Mirror
Set Immob. HEX to 0x0058 (check to make sure your old ROM was the same)
Live Map implmented
Option 3 - Thanks to l2r99gst 96533706 (v7 + Live Map + Speed Density) - Download |Mirror
Live Map implmented
Speed Density Implemented using the Fuel Temp sensor as input for Temperature
Option 4 96530706 (v7 + Mods) - Download | Mirror
mrfred psi based boost implemented as default (just edit Tephra's gear dependant map)
OBD II Inspection ready for EVAP and EGR
Disabled EGR, EVAP, and Idle Tests
Disabled P0300 code
Disabled lean spool
mrfred double fuel cut load limit implmeneted and set to 300 load (change to whatever you need this to be, read more)
Option 5 96531706 (v7 + Mods + Speed Density) - Download | Mirror
Everything that is included in Option 4 minus mrfred double load (not needed when switching to SD)
Please check jitter fixes per mrfred - Click here
Old Mar 16, 2015 | 08:53 PM
cerevo's Avatar
I'm revisiting doing this, I've downloaded all of the roms I think will work for me and are speed density since I'm not really set up to be MAF.
How do I know what my ECU ROM currently is? It did not come from my car, bought it used. super new to Evo ECU modding.
I think I figured out putting the .xml file into the OpenECU/Ecuflash/rommetadata folder with all the other .xml files, then opening the .bin with Tephramod on it, just want to make sure I use the right one.
EvoPower81
Sep 19, 2010 11:26 AM
iTune
Mar 26, 2010 04:56 PM
2JZfan
10
Aug 20, 2009 11:38 AM
InjectedPerformance
84
Jun 29, 2009 12:33 PM
