Something's wrong.
Old Apr 2, 2004 | 06:21 AM
instigator's Avatar
Something's wrong.
I'm not sure why my car doesn't want to make boost. I took out the Profec B and SAFC to install the UTEC. I was running 21psi with the profec and the car was making decent power. I installed my UTEC and now it's slow as hell. It is not the UTEC's fault though. For some reason, I am only able to make 13psi. I don't get it.
Here is a little background. I previously used the Profec for a boost guage. It worked pretty well since it has some nice peak functions. I went and bought an autometer boost guage to keep in the glove box for tuning since I want to have no guages visible in the car at all. I want it to look 100% stock. I also wanted to try to avoid the ABC for a cleaner install. I figured that 19-20psi to redline is plenty with that other additional features on the UTEC.
I removed the Profec and SAFC. The Profec was tapped for the guage at the fuel pressure line. I'd rather tap somewhere else, but it was working fine for the last 6 months. I tapped the autometer boost guage in the same spot and it only showed 12psi. No wonder the car is so slow. I went home and added the ABC out of curiousity since the map shows 100% BCS duty cycle at 100% TPS. I installed the ABC and I ended up cranking it wide open. Eight full turns and i am still only running 13psi. I don't get it. I have the cacuum lines exactly how they are diagramed on the underside of the hood and in the UTEC manual. It makes no sense to me. It was fine with the Profec, so I know nothing is mechanically wrong with the turbo. I haven't taken anything apart, so there should be no additional boost leaks now. I just don't get it.
Here is a log of a modified map. Look at my MAF signal. I see other people are seeing around 1700hz or more. That's what I was running before. Now I am lucky to see 1400hz.
Code:
    ,     ,     ,   ,Load,Knock,      ,      , Mod,  Mod,      ,  Mod
 RPM,  MAP,  MAF,TPS,Site,Count, Ign#1, Inj#1, Ign,  Fuel,Boost,  MAF
    ,  psia,  Hz, % ,    ,     ,  deg , duty , deg,   %  ,(OL) ,   Hz
 3267,+27.4,  62,  1, 00,   00,  +22.7,   5.0,ECU. , +0.0,ECU.  ,  61
 3264,+27.4,  62,  1, 00,   00,  +22.5,   5.0,ECU. , +0.0,ECU.  ,  62
 3236,+27.4,  59,  1, 00,   00,  +22.5,   5.0,ECU. , +0.0,ECU.  ,  61
 3242,+27.4,  61,  1, 00,   00,  +22.6,   5.0,ECU. , +0.0,ECU.  ,  58
 3287,+27.4, 336, 28, 10,   00,  +31.6,  10.0,ECU. , +0.0,ECU.  , 324
 3770,+27.4,  46,  1, 00,   00,  +34.1,   4.0,ECU. , +0.0,ECU.  ,  45
 3557,+27.2, 285, 17, 00,   00,  +38.8,   6.0,ECU. , +0.0,ECU.  , 363
 3944,+27.2,  80,  1, 00,   00,  +28.7,   7.0,ECU. , +0.0,ECU.  ,  35
 3691,+27.2, 358, 18, 00,   00,  +28.0,  10.0,ECU. , +0.0,ECU.  , 435
 4246,+27.2,  48,  1, 00,   00,  +38.0,  10.0,ECU. , +0.0,ECU.  ,  81
 4585,+27.0, 389, 27, 10,   00,  +29.9,  14.0,ECU. , +0.0,ECU.  , 377
 4403,+27.0, 437, 30, 10,   00,  +28.1,  18.0,ECU. , +0.0,ECU.  , 452
 4559,+27.2, 549, 33, 10,   00,  +26.1,  23.0,ECU. , +0.0,ECU.  , 576
 4694,+27.0, 874, 50, 10,   00,  +15.7,  35.0,ECU. , +0.0,ECU.  , 827
 4866,+27.2,1106, 87, 10,   00,   +8.8,  52.0,ECU. , +0.0,100.00, 988
 5058,+27.2,1068,100, 30,   00,   +8.8,  54.0,ECU. , -1.6,100.00,1162
 5307,+27.4,1101,100, 40,   00,  +12.3,  56.0,ECU. , -3.9,100.00,1024
 5537,+27.2,1184,100, 50,   00,  +13.4,  55.0,ECU. , -7.1,100.00,1136
 5777,+27.2,1222,100, 50,   00,  +15.4,  58.0,ECU. , -7.5,100.00,1041
 5973,+27.2,1170,100, 50,   00,  +16.2,  61.0,ECU. , -5.5,100.00,1146
 6195,+27.2,1340,100, 70,   00,  +18.2,  61.0,ECU. ,-11.9,100.00,1152
 6410,+27.2,1201,100, 60,   00,  +19.5,  63.0,ECU. , -8.5,100.00,1157
 6640,+27.2,1253,100, 60,   00,  +22.4,  64.0,ECU. , -9.1,100.00,1219
 6816,+27.2,1385,100, 60,   00,  +23.4,  64.0,ECU. , -9.5,100.00,1237
 7002,+27.2,1272,100, 60,   00,  +25.3,  65.0,ECU. , -9.5,100.00,1168
 7199,+27.2,1355,100, 70,   00,  +27.7,  63.0,ECU. ,-13.5,100.00,1201
 6600,+27.2, 156,  2, 00,   00,  +38.6,   7.0,ECU. , +0.0,ECU.  , 393
 6242,+27.2, 851, 63, 30,   00,  +31.4,  34.0,ECU. , -1.0, 83.00, 992
 5120,+27.2,1256,100, 30,   00,  +11.1,  55.0,ECU. , -1.2,100.00,1141
 5402,+27.2,1187,100, 20,   00,   +9.9,  63.0,ECU. , -0.5,100.00,1207
 5583,+27.2,1089,100, 40,   00,  +12.3,  60.0,ECU. , -4.9,100.00,1116
 5668,+27.2,1243,100, 50,   00,  +14.2,  57.0,ECU. , -7.7,100.00,1213
 5797,+27.0,1262,100, 60,   00,  +15.2,  59.0,ECU. , -9.7,100.00,1054
 5889,+27.0,1298,100, 50,   00,  +15.6,  61.0,ECU. , -6.5,100.00,1173
 6016,+27.2,1237,100, 60,   00,  +16.2,  62.0,ECU. , -8.5,100.00,1250
 6127,+27.2,1305,100, 60,   00,  +17.3,  62.0,ECU. , -8.5,100.00,1054
 6242,+27.4,1416,100, 60,   00,  +18.3,  63.0,ECU. , -8.5,100.00,1162
 6349,+27.4,1308,100, 80,   00,  +20.4,  60.0,ECU. ,-12.0,100.00,1072
 6459,+27.2,1326,100, 70,   00,  +21.5,  61.0,ECU. ,-12.4,100.00,1136
 6561,+27.2,1237,100, 60,   00,  +21.5,  63.0,ECU. , -8.6,100.00,1201
 6680,+27.2,1204,100, 70,   00,  +23.3,  60.0,ECU. ,-13.1,100.00,1184
 6775,+27.2,1373,100, 70,   00,  +24.6,  61.0,ECU. ,-13.5,100.00,1106
 6872,+27.2,1312,100, 70,   00,  +24.5,  61.0,ECU. ,-13.5,100.00,1190
 6973,+27.2,1269,100, 80,   00,  +25.4,  62.0,ECU. ,-13.4,100.00,1269
 7047,+27.2,1298,100, 70,   00,  +25.9,  63.0,ECU. ,-13.5,100.00,1116
 7168,+27.0,1416,100, 60,   00,  +25.9,  65.0,ECU. , -9.5,100.00,1275
 7246,+27.2,1432,100, 70,   00,  +27.0,  63.0,ECU. ,-13.5,100.00,1262
 7342,+27.2,1362,100, 70,   00,  +27.2,  63.0,ECU. ,-13.5,100.00,1157
 7423,+27.2,1432,100, 70,   00,  +27.6,  63.0,ECU. ,-13.5,100.00,1243
 7407,+27.2,  92, 27, 60,   00,  +36.9,   7.0,ECU. , -9.5,ECU.  ,  64
 6830,+27.2, 174,  1, 00,   00,  +38.6,  24.0,ECU. , +0.0,ECU.  , 169
 6138,+27.2,1077,100, 20,   00,  +26.8,  43.0,ECU. , -0.5,100.00,1020
 5402,+27.2,1275,100, 10,   00,  +10.1,  63.0,ECU. , +0.0,100.00,1336
 5611,+27.2,1173,100, 20,   00,  +12.2,  63.0,ECU. , -0.5,100.00,1225
 5640,+27.2,1179,100, 40,   00,  +13.3,  60.0,ECU. , -5.1,100.00,1033
 5717,+27.2,1269,100, 50,   00,  +14.2,  58.0,ECU. , -7.7,100.00,1121
 5747,+27.2,1216,100, 50,   00,  +13.5,  60.0,ECU. , -7.8,100.00, 988
 5797,+27.2,1149,100, 60,   00,  +15.4,  58.0,ECU. , -9.7,100.00,1302
 5858,+27.2,1259,100, 60,   00,  +15.4,  59.0,ECU. , -9.6,100.00,1213
 5910,+27.2,1262,100, 60,   00,  +15.5,  60.0,ECU. , -9.1,100.00,1179
 5973,+27.2,1219,100, 60,   00,  +16.3,  61.0,ECU. , -8.8,100.00,1179
 6038,+27.0,1259,100, 60,   00,  +16.3,  61.0,ECU. , -8.5,100.00,1116
 6116,+27.0,1288,100, 60,   00,  +17.4,  63.0,ECU. , -8.5,100.00,1201
 6127,+27.0,1190,100, 60,   00,  +17.3,  63.0,ECU. , -8.5,100.00,1269
 6172,+27.0,1219,100, 60,   00,  +18.4,  64.0,ECU. , -8.5,100.00,1231
 6253,+27.2,1259,100, 60,   00,  +18.4,  64.0,ECU. , -8.5,100.00,1152
 6277,+27.2,1176,100, 60,   00,  +18.4,  63.0,ECU. , -8.5,100.00,1269
 6325,+27.2,1210,100, 60,   00,  +19.5,  64.0,ECU. , -8.5,100.00,1141
 6410,+27.2,1373,100, 60,   00,  +19.4,  65.0,ECU. , -8.5,100.00,1162
 6435,+27.0,1216,100, 60,   00,  +20.5,  64.0,ECU. , -8.5,100.00,1146
 6510,+27.2,1207,100, 60,   00,  +21.7,  64.0,ECU. , -9.4,100.00,1152
 6535,+27.2,1432,100, 70,   00,  +22.6,  61.0,ECU. ,-12.7,100.00,1162
 6613,+27.2,1282,100, 60,   00,  +22.1,  63.0,ECU. , -8.9,100.00,1225
 6666,+27.2,1381,100, 60,   00,  +22.3,  65.0,ECU. , -9.1,100.00,1184
 6680,+27.4,1381,100, 60,   00,  +22.3,  66.0,ECU. , -9.2,100.00,1141
 6747,+27.2,1333,100, 60,   00,  +23.2,  65.0,ECU. , -9.5,100.00,1250
 6788,+27.2,1291,100, 70,   00,  +24.5,  62.0,ECU. ,-13.5,100.00,1256
 6816,+27.2,1474,100, 70,   00,  +23.8,  62.0,ECU. ,-13.5,100.00,1207
Any suggestions?
Old Apr 2, 2004 | 07:07 AM
Imprezd's Avatar
did you happen to remove the factory vaccum lines to install your profec boost controller?
Jermaine@turboxs.com
www.turboxs.com
Old Apr 2, 2004 | 07:17 AM
nmyeti's Avatar
www.turboxs.com
That was my guess. There is a restrictor that has to be in the right place or the boost control system isn't going to work well.
In the EVO there are two restrictor pills. The line off the compressor cover MUST have one of them and the second one is in the line running to the factory boost control solenoid. The second one can be removed to allow for higher boost pressure, but the removal of the first one will result in boost pressure being limited to right around your waste-gate spring pressure.
-Nathan
www.turboxs.com
Old Apr 2, 2004 | 07:19 AM
instigator's Avatar
I had them removed, but they are back to a stock configuration now.
Old Apr 2, 2004 | 07:35 AM
nmyeti's Avatar
Take a look and double check that you got the restrictor in the line coming from the compressor cover.
If it is there, then go into your UTEC boost map and at the low throttle positions type in a duty cycle of 75% from 500rpm to 2000rpms save the map and exit to the UTEC home screen.
Then pop the hood and stick your ear by the factory boost control solenoid. If it is not clicking, it's dead and that will be the source of your problem.
-Nathan
www.turboxs.com
nmyeti's Avatar
Oops... double post.
Old Apr 2, 2004 | 07:36 AM
instigator's Avatar
That makes sense. I *think* I am using the factory lines except for the 4mm line you supplied. The restrictor is between the compressor and the "T"?
-Nathan
www.turboxs.com
Old Apr 2, 2004 | 07:38 AM
nmyeti's Avatar
Correct.
Old Apr 2, 2004 | 07:40 AM
instigator's Avatar
I am almost sure that there is not one there. That must be the issue. Thanks guys!! I'll be sure to let you know once I take a look tonight.
Old Apr 4, 2004 | 09:52 AM
instigator's Avatar
It looks like the restrictor was the issue. Thanks again guys! I couldn't find the restrictor from the shorter compressor hose, so I used the one fro the longer hose. I am not able to make 19pis without the ABC, but it can at least be turned up to get back there. I am guessing that the original restrictor might be smaller than the one I am using. I'll have to go order the vacuum hose kit from Mitsu to see if that makes it any better.
Old Apr 5, 2004 | 02:33 PM
SuperchargedGTZ's Avatar
I am a little slow on the Utec lingo, but can or cant we use a MBC with the Utec. I am currently using dynoflash as my method of tuning, but my upgrade path in the next 2 months is becoming rapid and I def dont want to add a afr/afc. I am pretty knowledgeable with these but i am now looking to upgrade to the Utec. From reading around I have heard nothing but good things from this unit. I am getting pretty excited with this unit I am just afraid that I am going to need someone to help me with the system at first to become comfortable with the Utec.
Old Apr 5, 2004 | 02:40 PM
instigator's Avatar
I don't see why you couldn't use a EBC/MBC. I would just set the boost map on the UTEC to 0 all across the load ranges.
I was alittle frustrated on Saturday morning because it wasn't running as well as before, but I had only had it in the car for a few hours when I took it to autocross. After some time with it, I am already getting it running pretty well. After some dyno time, it should be set up pretty well with a few maps for different situations.
Old Apr 5, 2004 | 04:49 PM
nmyeti's Avatar
You can use an EBC/MBC with the UTEC. You don't have to do anything different with the UTEC's boost map.
-Nathan
www.turboxs.com
Old Apr 5, 2004 | 05:56 PM
-Nathan
www.turboxs.com
but do you suggest using one? I am really leaning toward the UTEC now. I picked up a laptop today to use for it, and some of my mods should be coming soon. I want to install the UTEC after the cams, injectors, and new FMIC
i am really getting excited now
Old Apr 5, 2004 | 07:13 PM
MalibuJack's Avatar
You can easily control boost with the UTEC, so another MBC/EBC is unecessary, it really depends on what you want to do with it.
nothere
Jan 2, 2007 08:02 PM
WarmPepsi
Oct 2, 2005 08:11 PM
SlowCar
10
Aug 4, 2005 07:29 PM
BigBoogieman
Apr 11, 2004 11:47 PM
