Knock Reading using FC Commander
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by Coolguy949
Wow , i am glad to hear you like it. My confidence in the unit has gone up now. I really like the commander and everything. I didnt want to sell it.
SO the base map is ok to drive around in?
Rob
Rob
couple questions because i'm desperately trying to digure out a stand alone system.
does pfc use the stock knock sensor and how good is the stock knock sensor, i've heard with other stand alones that an aftermarket sensor that is extremely sensitve is better (heard this from rex owners).
doe sthe pfc pull timing if knock is above warning level? this is important to me because i don't want to blow my engine.
you can convert to speed density right? so what wideband o2 sensor is used, ems can use gm or aem unit, are there options for apexi? does it come with one?
what is d jetro?
what is d jetro?
what is d jetro?
what is d jetro?
power fc is a stand alone fuel management system. it allows you to tune the fuel curve for different amounts of boost and allows you to change the method by which the ecu gathers air quantity information (maf or map).
the s-afc is a piggyback fuel computer. it uses the stock ecu's fuel map and tricks the ecu into putting in certain percentages of fuel that are more or less than the stock curve, these percentages are left for you to tune. there is also an advertised effect that the safc has that is similar to the eids, it is suppose to smooth out sudden changes in air so that the fuel compensation doesn't cause your engine to stall, i have never actually heard of anyone benefitting form this passive device on an safc possibly because no one knows it exists or how to turn it on. (HAS ANYONE EVER USED THIS ON AN SAFC???). eids however is getting pretty popular and more than a few people have installed it, i'm waiting on the results.
i guess i have a few complaints about the power fc now.
it does not come with map conversion ready.
the support just isn't here in the states.
it's relatively expensive unless you get it used.
it doesn't pull timing to save your engine.
it is more important that it pulls timing in an effort to save your engine because even if it blinks when there's too much knock, what's the most you can do? lift off the gas and hope you don't have to bend over and kiss your *** goodbye or rather your engine's ***. or cry. if there is a built in safety mechanism if something goes terribly wrong like your fuel pump fails or something even more realistic like you're in the middle of a high g turn and you suddenly hit a lean spot on two cylinders that are furthest away from the fuel rail inlet, you'll get more than just a blinking light, you'll get a timing pull that could just save your car. doens't matter how well you build your engine, if you don't tune it safely detonation will always break it.
R32 GTR
Jul 18, 2008 08:22 PM
JDM-Spec.com
Dec 1, 2004 10:01 AM
JDM-Spec.com
12
Nov 21, 2004 03:16 PM
