If your not stage 2, your probabaly getting passed
thats cool, lets try to get closer to topic now, no hard feelings, i don't really care i just don't want this thread to become cluttered. no updated as im in school right now though, i have a progress sway bar, thicker perches, and the first set of kartboy endlinks and bushings available for the progress sway bar for our cars waiting to go on along with a greddy turbo timer ready to go on next thursday when i get home to go to the SUBY / MITSU SHOOTOUT and Norwalk.
the shootout is in 2 weeks. I have no clutch. I have no money. No I was going to run but now my clutch is slipping badly, i'm goign to try to turn the boost back down to 5 psi and see what happens. Id like to run it there but I might wait till i get a new clutch, which could be a while, and run it at a more local dragway. Id like to get a clutch and flywheel so i can do them both while i have the tranny apart but id be happy if i could get the money together for a clutch let alone a flywheel. By far the biggest downfall of stage 2 is the traction / stock clutch issues.
Originally Posted by Boeturbolancer
LSD... thats the ticket!
A sponsorship must be a nice thing to have when your trying to build a car...
Originally Posted by Hotshot940
clutch + flywheel + lsd = $$$$$$$$ that i don't have.
Originally Posted by pgmike
boe how much of a diff did it make with your 60' times?
after lsd on stock tires 2.0-2.2avg
And i suck at launching... best launch i ever did was on slicks with lsd and that was a 1.8!
I put over 18k into my lancer before i called it done... then i went back to stock and i'm starting all over again.
Before lsd on stock tires 2.2-2.4 avg
probably... but with the lsd you'd be even better.
There's no doubting the difference it makes. Drive a car with one and compare. It corners better... launches better... and even pics up speed a lot better. I barely spun tires on my car at 13psi. All i was on was toyo proxies. There's guys running stock diff burning second from 4k on. It helps, no doubting it.
Like i said before... your either a serious player or a weekend warrior. You choose.
I got serious and lead the way for many... maybe you'll be the next. Right now OMAR is kicking ***... he's got the lsd! :hint: :hint:
It should only be done by a certified shop or really experienced mechanic. You have to take the tranny apart to do the swap. Some seals need to be replaced as they are ruined when taking it apart. Either have a dealer do it or pay RRM to do it for you. I wouldn't attempt it unless you knew what you were doing.
