Custom 16G6 Turbo Project
Originally Posted by MalibuJack
BTW I'm going to talk to one of the header vendors about producing headers with the evo twin-scroll flange already installed on it.. this will save you guys alot of headaches..
Originally Posted by initialDRacer
hey aznflip, can you give us a picture of the downpipe and how your wastegate is setup?
I don't have a pic of the downpipe yet, but I used the evo and customize to fit it.
Btw, please check the Lancer Engine Tech Forum, I started a thread there and need help.
can you give a brief overview aznflip of what all you bought and modified? i was thinking of doing the same thing. i read every page but i want to make sure i followed everything. mostly i feel my problem will be the downpipe.
It was bumped from the dead, but hey, why not post.
I am collecting parts for my 16g6 turbo project as well...theres alot to get/do so it might be a while. So far i have the turbo, ic, ic piping, bov, and the exhaust manifold is on the way. I work for an Engineering company, so i will have them work on the exhaust flange for me for little money, if that. So far i have spent only 500$..I will be buying the majority of the parts within the next month, and may have to be boosting during the winter..but i might be moving to florida, so hopefully some fellow lancer owners could help me out down there.
this company sells the flanger for our cars, scroll down to the bottom its 4G93 Mitsubishi the 4G93 is the same as our 4G94. It will cost you $36.
http://bmcrace.com/products/flanges/
Im also turboing mine with the whole turbo mani, IC and pipes, and DP from a evo. ill have to do some fabing to the parts but ill get it to work.
yeah sounds good guys, i was pretty lucky and found a evo8 that was totaled in lansing which isnt far from me that i got parts from for pretty cheap.. Thanks for the offer z-lancerman..if i can get the parts in time before i might leave i might haveta take you up on that. I might be able to get my shop to fab up a exhaust flange for free out of stainless steel, and weld it back together..if not then thanks alot for the link. Good luck with your turbo endeavor as well 01g wrx 02.
bumpity.... harr harr.
I have questions
Brand New SS Custom Turbo Manifold: $325.00
Brand New SS Custom Evo O2 Housing: $50.00
what is the 02 housing? Im confused on this part.
FMU? what is this doing, something with fuel or boost?
to get the mani to work you cut that flange off and bolted on a lancer flange!? what kinda flange was used to do this? whats the "SS" stand for?
Im looking to peice myself a kit together now as well although im going for a tuneable set-up with a ecu upgrade. any additional info that wasnt touched on would be great. Ive read through twice now but confused on a few things.
I have questions
I have questions
FMU?
it raises the fuel pressure under boost to add additional fuel
it appears that others have just drilled the new holes in the 4g63 flange
stainless steel
what else you confused about?
I have questions
FMU?
stainless steel
