Parts to a turbo setup
Old Feb 19, 2003 | 11:46 AM
zlancer's Avatar
8 psi is the MAX I would consider to run on the stock motor with stock compression. That is what i'm running right now.. like between 7-8 psi. i think some problems are coming up with my motor but i'm not too sure yet. i just don't trust it at all. i would stick with about 6 psi just to be safe.
also get the Walbro 255 l/hr fuel pump for a 2G eclipse. that will work with the lancer with a little bit of force. the AEM FPR works i believe...just ask link286xt..he used one
Old Feb 19, 2003 | 11:47 AM
BuMpS's Avatar
Z thanx a lot bro... i'll stick to 5-6 shouldstill have some nicegains with that, hope to beat a basiclly stock wrx.
Old Feb 19, 2003 | 12:17 PM
uranium9v's Avatar
not too sure that fuel rail will fit either...check it out first.
Old Feb 19, 2003 | 12:29 PM
HobieKopek's Avatar
Bahamut, or anyone who knows, would something like E-manage be able to correct for the difference in ohms or would the stock ECU still be controlling them? I will be doing fuel upgrades in the near future and I could use all the help I can get finding larger injectors that will function properly.
Old Feb 19, 2003 | 06:15 PM
BuMpS's Avatar
Hey guys hmm i know this was discussed before but what is the benifit of having the blow of valve blow back of into the intake? just askincauseof piping...
Old Feb 19, 2003 | 06:18 PM
zlancer's Avatar
get it blowing back into noncompressed side of the intake...this will save you from a lot of headaches.....if it blows off into the air it makes the car run rich and stall.
Old Feb 19, 2003 | 06:22 PM
BuMpS's Avatar
mucho gracias!
Old Feb 19, 2003 | 07:28 PM
BuMpS's Avatar
Aight gettin the side mount intercooler by this weekend ... Zlanc u've (PM'd) me before sorry i never got back by the time i realized it had been a while i read about u doin your setup any knowledge you got man would b greatly appreciated
Old Feb 19, 2003 | 10:07 PM
bahamut's Avatar
I think the ohms are regulated on the injectors itself. I don't think EM can change ohm readings on the car.
For larger injectors, check out rcengineering . . . plug in the turbo formula. I can't remember which is which. NA uses high or low impedance?
check out the last gen prelude SH. It might have 300cc injectors, but I don't know if they fit. The matrix has 300cc too, but the plugs look different and longer than mitsu design.
After getting injectors, always get 2 rubber grommets for each injectors. Don't want leaky injectors.
Old Feb 19, 2003 | 10:08 PM
bahamut's Avatar
W/ SMIC, you might not get enough boost. What is your HP goal?
Old Feb 19, 2003 | 10:53 PM
pjal84's Avatar
He only wants about 8 PSI of boost so it would seem his injectors are fine with a bigger fuel pump and FPR. I don't think he needs a terribly large IC since he'll be running low boost and the SMIC should help keeping a pressure drop to a minimum. As for the impedence of the injectors, NA uses high and FI uses low.
Old Feb 19, 2003 | 11:32 PM
HobieKopek's Avatar
Singling you out again, bahamut. Did anyone try that 10ohm resistor trick? With my extremely limited knowledge it makes sense, but I dunno.
Old Feb 20, 2003 | 12:06 AM
BuMpS's Avatar
ya like I said I planned on running 7-8 Pounds but i'm prolly only goin to run 5-6 due to the fact from what i hear 7-8 pounds can b bad over long periods and i fear losing my the bottom end of my engine...my hp goal well i was tryin to get as close to 220 as possible. but now i'm figuring i'll b lucky to hit 180 hp.really just want to smoke my bois wrx.
Old Feb 20, 2003 | 12:10 AM
BuMpS's Avatar
Sorry it's late my typing skills are lacking eventally prolly after i add my body kit i'll go front mount...
Old Feb 20, 2003 | 12:28 AM
Link286XT's Avatar
you might also want to change your stock thermostat, mine stuck shut and my engine overheated, so i fried my piston rings. just heads up.
Link
