would this work???
Old Oct 15, 2008 | 07:01 AM
m3ta11ica12345's Avatar
Question would this work???
HTML Code:
http://ststurbo.com/universal_system
would a universal turbo kit work? anythoughts on this?
Old Oct 15, 2008 | 07:04 AM
lancer2show's Avatar
it looks like it might. how much does it cost? i know those kits are usually common for like vettes etc. why dont you just get a regular turbo kit?
Old Oct 15, 2008 | 07:08 AM
bcollinstex's Avatar
They will, you will still need to custom fit the piping, make a custom manifold, injectors, fuel pump, etc.
You'd be better served and save money by piecing a turbo kit together yourself. Several guys on this forum have built a turbo kit for less than 2 grand. Probably not with new parts, but you can save money and have boost too.
Old Oct 15, 2008 | 07:16 AM
i was lookin at this cuz it was cheaper only 2k and i no ppl hav built good custm kits cheap but i dont no enough to make a custom kit. id do reasearch and build one but even then i dont trust that it would work.
Old Oct 15, 2008 | 09:55 AM
it seems like it uses the same concept since turbo is run by exhaust. thats pretty much a universal kit..so you still would have to do some custom designing to make it work.
Old Oct 15, 2008 | 10:02 AM
ambystom01's Avatar
If you're new to turbos and don't have the time/desire to do a lot of research, I would suggest the RRM kit.
Old Oct 15, 2008 | 10:17 AM
i would do the research i just dont trust a custom kit or anything thats not proven. im also having a hard time finding the piping i would need for a turbo kit. i like the rrm kit but im just tryin to find something cheaper.
Old Oct 15, 2008 | 10:22 AM
what exactly would i have to do to make it work? would i need any additional parts? the kits only 2k so if im really considering this as a decent option. would i get the same kinda power outa this as opposed to the rrm or tsi kit?
Old Oct 15, 2008 | 10:58 AM
doctorjon's Avatar
I would just buy the 600 dollar universal kit on ebay.
http://cgi.ebay.com/ebaymotors/02-06...mZ230298555613
it has more to offer than the kit your looking at.
---Edit---
None of these kits offer any manifolds. You than need to get one fabricated or buy one that fits a t3/t4 flange. The universal kit your looking at doesn't offer a FMU or FPR the ebay kit does.
This one is located in japan...would take awhile to get to you, but could be worth it.
http://cgi.ebay.com/Mitsubishi-Lance...3286.m63.l1177
Old Oct 15, 2008 | 12:14 PM
600 dollars for a turbo kit? its gotta b a POS. no way a 600 dollar kit could compete w the 4200 dollar kit rrm sells. i still want a decent kit. im tryin to find a good balance between quality and price. rrm is the best there is but its to expensive for me, i want somethign just a lil bit cheaper like 2k - 2.5k
and the one from japan is for the 4g63 and 4g62 engine. my car has the 4g64
Old Oct 15, 2008 | 12:19 PM
doctorjon's Avatar
well that kit on ebay does look dependable. It can't compete with RRM because their kit is an actual whole. The ones i posted were universal kits like the ones your looking at. If your looking for a kit that has a name heres one
http://www.wcturbo.com/TurboBoltOnKits.html
---Edit---
More...
http://www.nolimitmotorsport.com/prod/ML2501-X
http://www.prostreetonline.com/pnsku/ml2501.asp
Old Oct 15, 2008 | 12:23 PM
doctorjon's Avatar
Here is another place that sells turbo manifolds for lancers other than RRM
http://www.importperformanceparts.ne...man-mitsu.html
Old Oct 15, 2008 | 12:26 PM
oh wow thoes r some good finds. they all look legit but r thoes kits good? im thinkin bout gettin the superior kit from rc turbo now. that seems perfect for me, rigth in my price range. but i just wanna make sure its dependable and i wanna make sure ill get a decent amount of power outa of it.
edit: btw im lookin to get about 200 - 250 hp outa my car in the end. im prob gonna get new pistons and rods and bumb the boost up to 10, maybe few other mods. u think ill get the numbers im lookin for if i do that?
Old Oct 15, 2008 | 12:29 PM
drucea's Avatar
OK, do you guys know what a remote mount is? That's the rear mounted turbos (usually) in place of the muffler or anywhere else in the exhaust. It's good because you don't need a manifold. You have it put into your exhaust pipe. I was planning on doing this when I started my build but decided against it.
The money you save on a turbo manifold, you end up spending on a pump to return the oil from the rear of the vehicle up to the motor.
Turbos get very hot, imagine after a hard drive, you hit a puddle and the turbo gets cold water splashed on it. It could crack.
Rather than all the short pipes in the engine bay, you'd need to run the compressor pipe all the way back to the throttle body. I couldn't find much room and it would end up close to the exhaust, defeating one purpose of a rear mount (no intercooler needed since the return pipe to the TB acts as a cooling system).
With our MAF sensor, you'd have to extend wires all the way to the back of the car, or run the intake pipe with filter and sensor all the way back into the engine bay. I wouldn't trust having my MAF sensor under the car where it could get easily damaged.
But other than that it's just like any other turbo kit. You need the same parts. I think they look cool. I wanted one after I saw one on a WS6. I'd say stick with the normal turbo in the engine bay. It's less of a pain and is proven to work if done right.
Old Oct 15, 2008 | 12:30 PM
drucea's Avatar
Also, if you get pistons and rods, you could probably turn the boost passed 10 psi. And with that you'd definately get the numbers you're looking for if it gets tuned right.
