Yet another thread about Turboing a 03 lancer.
Old Dec 13, 2011 | 07:52 AM
  #1426
02-Lancer-Es's Avatar
The way i know is that in my final gear on the hwy at exactly 70 mph (Gps) I'm at 3012 Rpm .
So 70/3000=0.023333333333x6700= 153.33333
Old Jan 29, 2012 | 01:09 PM
  #1427
03lances's Avatar
Just thought I would give an update. Car has been running great pushing 14-15 psi. RyanCB and I will be bringing both our cars to English Racing on Feb 3rd which should be alot of fun :-). I still have my idle dips. Still cant figure out the problem. Just put brand new plugs in yesterday hoping (although assuming no) it would fix or help the problem which it did not. Hoping maybe Aaron down at ER might give me some insight and steer in the right direction on how to solve this issue. Seriously debating replacing the front 02 sensor but I still dont believe this is the issue. I can switch to full open loop even at idle to bypass the 02 sensor but I still get dips which leads me to believe its not the issue does this make sense? Any thoughts?
Old Jan 29, 2012 | 01:12 PM
  #1428
slatermvp's Avatar
I have kind of the same issue but its because my belt is slipping on the altenator so the voltage drops as well as my rpms until the belt grabs again. It's real quick though.
Old Jan 29, 2012 | 01:14 PM
  #1429
03lances's Avatar
Here is what my car has been doing for the past couple months. With my awesome cracked cluster cover lol. I wanna know how someone did that.
http://www.youtube.com/watch?v=mPiOxX9UsEk
Old Jan 29, 2012 | 06:54 PM
  #1430
burner67's Avatar
what dv are you using? the evo one?
Old Jan 29, 2012 | 07:13 PM
  #1431
ryancb's Avatar
he is, mine is doing it as well but not as bad. We both are fairly sure its in the tune.
Old Jan 29, 2012 | 07:18 PM
  #1432
slatermvp's Avatar
if both of you are doing than it would definitely be something in the tune. In the video it sounds mechanical but if both of you are having the issue then its different than mechanical.
Old Jan 29, 2012 | 07:23 PM
  #1433
ryancb's Avatar
I think last thought was something with ISCV table since it seems coolant temp related.
Old Jan 30, 2012 | 12:41 AM
  #1434
burner67's Avatar
mine also does it, and dies after high revs when im stopped. or when i pull it out of gear.
Old Jan 30, 2012 | 12:43 AM
  #1435
ryancb's Avatar
mine used todo that with the lightweight flywheel. haven't been pushing the car hard as of late but it deff hasn't done it as much.
Old Jan 30, 2012 | 01:06 AM
  #1436
03lances's Avatar
I have messed with those ISCV table till my eyes bleed lol. I may be missing something though idk. BTW Ryan I make good headway on that explorer tonight so hopefully it will be all done tomorrow before work
Old Jan 30, 2012 | 07:39 PM
  #1437
burner67's Avatar
yeah i tried everything in the tune to make it stop doing it with no luck. can the dv being open at idle cause any of this?
Old Jan 30, 2012 | 07:59 PM
  #1438
ryancb's Avatar
I have no idea but i think that shouldn't be the issue since I'm on a diff dv then you guys.
Old Jan 30, 2012 | 09:55 PM
  #1439
03lances's Avatar
I ran same dv for a year and a half with non of this crap. Dunno what changed honestly
Old Jan 30, 2012 | 10:33 PM
  #1440
ryancb's Avatar
also makes no sense why when cold its fine
