tdo4hl-15g turbo
Correct. If you're looking for the best availability of parts to turbo your Lancer, the 16G6 turbo is the one you want. If you are adamant about sticking with this turbo then you'll need to find a fab shop because everything will be custom (and costly). I can understand how some people will pick the turbo and build their kit around that. However, in this case it is not the best option. Trust me, the 16G6 won't let you down.
search , we dont get paid to answer questions .lol seriously you'll need the same thing as turbo'ing any other car ...
different heat range plugs
bigger fuel pump
wideband air/fuel gauge
adjustable fuel pressure regulator
down pipe
something to tune the computer with etc
__________________
Higher boost:
arp head studs
pauter connecting rods
forged pistons
... its not something to be taken lightly a wrong tune and even 6psi you'll be walking down the highway picking up your connecting rods ....
a td04 is a small lil guy ,Im pretty sure it has a bigger outlet housing then a dsm turbo but the flange is different , and I also believe the turbo is a low pressure model meaning it'll be worthless , if anything look for a garrett t-3 if you wanna go custom.
we sell a manifold that will directly bolt a 16G evo 8 turbo to the lancer head allowing you to use the evo 8 intercooler,pipes,downpipe and intake
bigger fuel pump
down pipe
__________________
Higher boost:
arp head studs
forged pistons
here are a bunch of build threads that ppl have made going the 16 route
https://www.evolutionm.net/forums/la...g-install.html
https://www.evolutionm.net/forums/la...st-lancer.html
https://www.evolutionm.net/forums/la...urbo-soon.html
https://www.evolutionm.net/forums/la...ing-turbo.html
https://www.evolutionm.net/forums/la...cer-forum.html
https://www.evolutionm.net/forums/la...other-16g.html
https://www.evolutionm.net/forums/la...o-project.html
https://www.evolutionm.net/forums/la...6-project.html
https://www.evolutionm.net/forums/la...o-8-build.html
https://www.evolutionm.net/forums/la...16g-build.html
https://www.evolutionm.net/forums/la...03-lancer.html
bigger fuel pump
down pipe
__________________
Higher boost:
arp head studs
forged pistons
bigger fuel pump
down pipe
__________________
Higher boost:
arp head studs
forged pistons
get bigger injectors( preferably wrx 440cc injectors) and a walboro 255 fuel pump. then get your car flashed. good tuners dont even touch fuel pressure regulators until 500+hp.
is there any internals i will need to change
ive been told better head studs and rod bolts is all but im not sure
bigger fuel pump
down pipe
__________________
Higher boost:
arp head studs
forged pistons
bigger fuel pump
down pipe
__________________
Higher boost:
arp head studs
forged pistons
Chope045 bro just read the threads man no one is going to keep giving you answers unless you read them!!! We all did the research some of us have turbo lancers, some of us are getting ready to build "me of course" and I had to read every thread in order to get my questions answered
i got a manifold and turbo and piping, not sure what turbo, ill look, not 16g but i could get rid of it dirt cheap prolly, just took it off the 03 lancer 0z i have, if u want more info, pm me
boomtown
83
Feb 2, 2022 03:58 PM
evo5christchurc
17
Aug 15, 2013 01:27 PM
MR.Maxwell
Jun 28, 2013 08:41 PM
