Going turbo but got some questions
yeah steven that correct...I have the correct address and its set up for developer.
It tries to read the ECU when before it wouln't do that because I had it to the wrong address but now its all set.
it tries to the red the ecu using kernel but since I have an 05 it should be using kernelocp, I think from reading through the threads but I don't know how to make it so that it uses kernelocp and not kernel.
Its probably becuase my read template was meant for a older model.
I've created a package of both for you try the 06-07 version which switches the flash method to ocp like its supposed to.
yeah i unzipped that already and put in my read template folder but it still keeps going to kernel...am I suppose to put it in a different folder??
oops, hang on didn't realize that new one had two xml files, let me go try it
That worked it read the ecu. THANKS BRO!!!!!!!!!!!!!
now I gotta figure out as to why its saying its corrupt. It says it doesn't have a definition file for it. Do I just choose one of the inherited ones from a 2005 lancer es. I don't know my rom id and don't know how to get it or where to find it.
I know I keep asking alot of questions but I have tried to figure it out by myself using the internet. Roadspike and Steven thanks alot for the help so far guys!!!!!
sorry senate but I did the inherited one before I saw your message...i chose the inherited option, I chose the first 05 lancer option above (86640007) and it gave me ROM ID 86640008. Is this ok or can I re-do it??
I re-read my ecu after doing that but it didn't ask me anything the second time. I see the maps in ecuflash no prob.
Did I do something wrong?? When I'm in the home screen in ECUflash in the ROM info section next to ECU id there's nothing there but I do have a number on the Internal ID number which is the same number I got as my ROM ID.
another stupid question but what size vaccuum T's did you guys get. I was going to order them online but it asked me for sizes. Imma go to Autozone or advance autoparts tomorrow and see what they got. I also have to get the coolant line and a hose for the BOV.
bring your turbo up there to measure for the coolant lines, and there is a tee that you can cut what size you need for the hoses, I have one and it works amazing
https://www.napaonline.com/Catalog/C...811_0282385264
I just went to advance and they had a kit with multiple types of tees for around 5 bucks. I just got that.
^ oh ok cool. I think a kit would be better for vaccuum Ts.
For the coolant lines I was thinking of doing it the way JRR did it. Basically the coolant by pass mod with a turbo. I gotta find the picture of it and save it to my computer.
