Going turbo but got some questions
Old Apr 12, 2011 | 02:55 PM
  #226
slatermvp's Avatar
what size did you use Steven??
Old Apr 12, 2011 | 04:47 PM
  #227
slatermvp's Avatar
would a regular 02 bung work for a wideband sensor??
Old Apr 12, 2011 | 06:32 PM
  #228
JRR's Avatar
JRR
yes as long as its an 18mm sensor. most of them are, but double check.
josh
Old Apr 12, 2011 | 07:09 PM
  #229
slatermvp's Avatar
alright cool. What about the other questions. getting close now.
Old Apr 12, 2011 | 10:57 PM
  #230
steven121's Avatar
yes a reg O2 bung will work wih the wideband, when I bought my test pipe it was a direct fit, although I do need another hole for my rear O2 sensor the CEL comes on and of once in awhile depending on weather conditions
Old Apr 13, 2011 | 01:05 AM
  #231
burner67's Avatar
Im pretty sure all the main bolts on the turbo and o2 housing are m10x1.25
Old Apr 13, 2011 | 09:54 AM
  #232
slatermvp's Avatar
sweet, thanks
Old Apr 13, 2011 | 10:15 AM
  #233
slatermvp's Avatar
how about saving the stock ROM?? just read and save as??
Old Apr 13, 2011 | 10:21 AM
  #234
steven121's Avatar
on ecu flash click read rom, let the computer do its thing, and then click save as, name it stock rom, or orig lancer rom something you know that its the stock version then save it and make copies just in case if you have a virus one day that melts down your cpu
Old Apr 13, 2011 | 11:11 AM
  #235
slatermvp's Avatar
ha ha...good advice gonna do that tonight.
Old Apr 13, 2011 | 06:17 PM
  #236
slatermvp's Avatar
sorry one last stupid question...i don't need to add anything when i save it right...like stock rom.hex or stock rom.zip or something like that, I can save it as "stock rom" and nothing else after that right??
Old Apr 13, 2011 | 08:36 PM
  #237
HornstarBU's Avatar
It'll add a file extension to the file name on it's own I bet. Doesn't hurt if it doesn't you could just add it on....a file is a file.
Old Apr 14, 2011 | 04:26 PM
  #238
slatermvp's Avatar
ARP headstuds came in today. I ordered the maintenance stuff like headgasket, valve cover gasket, etc and once a some funds or my stock ES tailights sell I'll order the stuff for the oil feed/ return lines and then I should be ready to go.
Currently I'm trying to figure out what my options are for tuning the ecu since I don't think there has been a single turboed 04-06 lancer that has been using the stock ecu. Most have used the piggyback system from RRM. Gotta keep reading.
Old Apr 14, 2011 | 06:59 PM
  #239
corndog17's Avatar
Nice, my block was just bored to for my new forged pistons, as well as the fly wheel. Getting ready to assemble my motor as well with ARP head studs. Trying to locate the ARP main bolts and ARP fly wheel bolts but the flywheel bolts are irregular dimensions 11mm head. The ones ARP offers are a bit long so Id have to cut em down shorter. I eventually going to turbo but for now justh ave the built motor and piece together the turbo kit as I go, probably going to have to use a stand alone fuel management system as well.
Old Apr 14, 2011 | 07:11 PM
  #240
slatermvp's Avatar
yeah i'm putting everything on the blown motor first then transfering it over to the car. Once the turbo is on imma start diassembling the blown motor and hopefully if its not too bad I can rebuild it for when the motor in the car goes.
Once that's done I can start working on the vw 16v engine so I put ITBs on that.
