Going turbo but got some questions
Old Feb 2, 2011 | 09:04 PM
  #121
burner67's Avatar
I can't i have an 05 lancer will external slave... i might just see if someone local can build me one to clear that thing. i really dont wanna pay $400 for rrm plus their o2 and then a external wastegate. and from what i hear rrm mani has cracked on some people
Old Feb 3, 2011 | 04:26 PM
  #122
slatermvp's Avatar
i'm planning on getting a speedcorps one as well once my taxes get here...so far I have gotten lucky on prices but imma shell out the money on the manifold if I can't find one used.
Old Feb 3, 2011 | 05:40 PM
  #123
steven121's Avatar
Used manis are hard to come by... trust me I looked for awhile and I gave up. It's not impossible just not very likely
Old Feb 3, 2011 | 06:27 PM
  #124
slatermvp's Avatar
yeah thats what I was thinking, might as well spend the money on it...next buys are going to be tactrix cable, turbo mani., and wideband. hopefully with the tax money. I want to be turboed by April but it doesn't look like its going to happen but we'll see what happens.
Old Feb 3, 2011 | 08:22 PM
  #125
JRR's Avatar
JRR
^^u have seen my pics about the sc mani and an 04 trans right? or are you auto i cant remember....
Old Feb 3, 2011 | 08:53 PM
  #126
burner67's Avatar
i would love to see this picks cuz i havent yet. and speaking of tax returns i only get $16 back
Old Feb 3, 2011 | 09:01 PM
  #127
JRR's Avatar
JRR
yes i have an 03 but grenaded the trans so i swapped in an 04. the sc mani will NOT clear the external slave if you are m/t. now i like the trans because it makes everything modular and can be changed easilly and most without dropping the trans...
josh
Old Feb 4, 2011 | 07:31 AM
  #128
burner67's Avatar
thanks for the pics! will it be the same situation with a 4g63 mani with a flange welded on?
Old Feb 4, 2011 | 09:56 AM
  #129
JRR's Avatar
JRR
i would believe so. the evo's slave is 180 the opp way so it dont matter but for us we are screwed...
Old Feb 4, 2011 | 12:38 PM
  #130
slatermvp's Avatar
I'm auto so I don't have that issue.
Old Feb 4, 2011 | 07:19 PM
  #131
Jogenmaru's Avatar
Sorry Im not trying to jack slatermvp's thread but I have a few questions. Ive got an evo 8 turbo and I feel as if Im missing a return line but have no idea which one.
I already have the one for this hole. What size bolts are they on the sides?
Which one is this for? the top one
And this one?
I have these 2 left and already know where one of them goes.
Im a little bit lost as to which line is which? As you can see there are 3 extra holes and i only have 2 extra lines. Should I just buy this and call it a day and know which each are?
I can make another thread if need be OP, if you would like me to. This will be one of my last steps other than buying another forge wga as the one I have all the allen bolts are stripped and I cant remove the current 18-25psi spring inside.
Or could I just remove them and get new bolts to go in there spots and rethread of course?
Old Feb 4, 2011 | 07:35 PM
  #132
RoadSpike's Avatar
1) Return hose bolts are 10mm head M6x20mmx1.00 pitch thread
2) Coolant line (bidirectional) m14mm x 1.5 thread pitch
3) Oil feed uses a bolt size M12x1.25 thread pitch
4) Top line is the oil feed line to the evo head probably not useful to you
Bottom line is the oil return line which goes to the oil pan
You're missing a water coolant line. I suppose you could opt to use AN lines for everything including water.
Old Feb 4, 2011 | 08:08 PM
  #133
Jogenmaru's Avatar
Ok cool. thanks
Old Feb 5, 2011 | 07:00 AM
  #134
slatermvp's Avatar
you ain't hijacking bro...I would have had those same questions if it weren't for me picking up a turbo with all the lines on it.
Old Feb 16, 2011 | 08:26 PM
  #135
cedes14bamg's Avatar
can you start and drive a car that will have bigger injectors? like lets say the turbo install is finished and its not an FMU its bigger injectors installed, can you drive to the tuning shop like that?? on boost set low with boost controller
