Going turbo but got some questions
Subscribe
Feb 16, 2011 | 09:15 PM
  #136
Quote: can you start and drive a car that will have bigger injectors? like lets say the turbo install is finished and its not an FMU its bigger injectors installed, can you drive to the tuning shop like that?? on boost set low with boost controller
Depends on how much bigger your talking but generally not if its not tuned at least somewhat for the bigger injectors. Reason being is if you for instance installed some 440s and tried running without tuning then the computer still thinks you have the stock 240s in. What this does is the computer will still open the injectors for the same amount of time as they did with your stockers only your new injectors have the capacity to flow twice as much and so you will be spraying out roughly twice the amount of fuel that computer thinks its releasing.
Reply 0
Feb 16, 2011 | 10:45 PM
  #137
It's all about scaling and latency I'm still a little unsure how latency works but that will be the key factor for idle
Reply 0
Feb 17, 2011 | 09:29 AM
  #138
Quote: It's all about scaling and latency I'm still a little unsure how latency works but that will be the key factor for idle
latency is injector dead time.
In other words the number of ms it takes for the valve to open when applying some voltage to it. Remember its still a mechanical device you can't assume it will happen immediately
Reply 0
Feb 17, 2011 | 11:16 AM
  #139
Quote: Depends on how much bigger your talking but generally not if its not tuned at least somewhat for the bigger injectors. Reason being is if you for instance installed some 440s and tried running without tuning then the computer still thinks you have the stock 240s in. What this does is the computer will still open the injectors for the same amount of time as they did with your stockers only your new injectors have the capacity to flow twice as much and so you will be spraying out roughly twice the amount of fuel that computer thinks its releasing.
alright thanks.
umm anybody knows any other car that would be fun to have an evo 3 16g in ...? besides talon/eclipse 1g and 2g and besides lancer...
long story short i dont have my lancer anymore !
Reply 0
Feb 17, 2011 | 11:20 AM
  #140
I was thinking about putting one on a liter bike :P
Reply 0
Feb 17, 2011 | 02:38 PM
  #141
well I know that, Im just not suer how you scaled it... like did you take the oem numbers and just lowered/raise them to get the proper latency?
Reply 0
Feb 17, 2011 | 02:47 PM
  #142
Quote: well I know that, Im just not suer how you scaled it... like did you take the oem numbers and just lowered/raise them to get the proper latency?
Something like that. What i tend to do is use multiplication on the tables for scaling up latency.
Its not a perfect science but on average if the desried idle is 14.7 AFR and the car is running open loop at 12AFR we got a 8.3% difference in fuel. We need less fuel at this point so what I'd do is take about half the precentage 4% in this case and subtract it from 100%. The resulting 96% or a multiplier of 0.96 is done on the latency table.
This preserves the curve of latency that most if not all injectors have. So when scaling injectors you always want to preserve that curve for situation when battery voltage drops like starting or AC on.
Reply 0
Feb 17, 2011 | 07:47 PM
  #143
That made a little more since I'm going to have to play with it so I can get use to it
Reply 0
Feb 21, 2011 | 06:04 AM
  #144
Is Speedcorps the only place to get the wastegate actuator 5-8 spring from or are there any other options out there. Can the evo wastegate actuator be modified to run low boost like 5-8lbs??
Reply 0
Feb 21, 2011 | 09:28 AM
  #145
Quote: Is Speedcorps the only place to get the wastegate actuator 5-8 spring from or are there any other options out there. Can the evo wastegate actuator be modified to run low boost like 5-8lbs??
You can order the spring kit off the forge website. It has the 5-10 psi spring in it.
Reply 0
Feb 21, 2011 | 10:20 AM
  #146
Quote: You can order the spring kit off the forge website. It has the 5-10 psi spring in it.
This is where I got mine from just bought the whole kit.
Reply 0
Feb 21, 2011 | 05:34 PM
  #147
I'm having a hard time finding it can someone post up a link, please.
Reply 0
Feb 21, 2011 | 05:41 PM
  #148
I think he is talking about this
http://www.forgemotorsport.com/conte...t&catalog=0019
Reply 0
Feb 21, 2011 | 05:47 PM
  #149
alright cool thanks jogen...I need the diaphragm right instead of the piston one?
Reply 0
Feb 21, 2011 | 07:14 PM
  #150
Yes
Reply 0
