My 05 lancer turboed lancer thread...never thought it would happen
Old Jun 27, 2011 | 10:06 AM
  #241
steven121's Avatar
Just use your mouth to blow in the turbo lol
Old Jun 27, 2011 | 12:52 PM
  #242
slatermvp's Avatar
lol...did it work for you.
Old Jun 27, 2011 | 01:02 PM
  #243
burner67's Avatar
just pressure it and have someone watch the boost gauge for you and have them tell you when it gets to 8 or so
Old Jun 27, 2011 | 01:04 PM
  #244
HornstarBU's Avatar
Originally Posted by slatermvp
I don't know what my idle was at before I put the turbo on.
how would I pressurized the system bro. I have an air compresser but no valve to limit how much goes into it.
Do not use an air compressor without a pressure regulator. Get a connector, and a regulator from harbor freight. If you pressurize the system to like 50 or 60 psi, something is bound to break.
Old Jun 27, 2011 | 10:54 PM
  #245
slatermvp's Avatar
I'm buying a vaccuum block tomorrow froma local so we'll see if that makes a difference.
Old Jun 27, 2011 | 11:01 PM
  #246
slatermvp's Avatar
In other news though my altenator belt snapped off on the way home tonight from work.
I had reflashed the ECU and was at about 85 load when I noticed my battery voltage drop to 12 which very quickly made me worried. I look at the cluset and my battery and brake lights were on. Everything else was on and the car never shut off.
I pulled over and noticed my alternator belt was just dangling. Lady luck had other ideas for me. I was planning on changing the belt on Thrusday which is my next day off but I have to do it tomorrow morning.
I drove home for about 50 minutes on just the battery, turning my lights off whenever there wasn't a car around to conserve some battery life. It made it home though which I'm happy about.
Old Jun 29, 2011 | 12:53 AM
  #247
burner67's Avatar
that really suck man!
so im not sure if its just 05 up but when i do a boost leak test all my pressure seem to leak out of the vacuum control valve. Do the older lancers have those? its on the very left of the intake manifold. Its also labeled in the vacuum routing diagram on the hood.... when i pressure it to 8lbs it seeps out the stupid valve out till 3 and chills there
Old Jun 29, 2011 | 01:01 AM
  #248
hector787's Avatar
car looks good but the rims kill it
Old Jun 29, 2011 | 04:50 AM
  #249
link62's Avatar
If it's the pink thing I had a leak from that when i when i did a boost leak test also so i just removed it and capped off the lines
Old Jun 29, 2011 | 06:49 AM
  #250
slatermvp's Avatar
burner any way you post a pic of what you are talking about. I don't remember seeing a pink things.
I bought a BLOX vaccuum plate yesterday from a local guy so I'm going to route all my vaccuums to that tomorrow along with putting on the new altenator belt. It's my only day off so I gotta do it tomorrow.
Old Jun 29, 2011 | 10:38 AM
  #251
burner67's Avatar
check my thread i posted a pic
Old Jun 29, 2011 | 10:41 AM
  #252
slatermvp's Avatar
yeah I just saw it. thanks
Old Jun 29, 2011 | 11:43 AM
  #253
burner67's Avatar
are you still not making any boost?? i think its your wastegate actuator you eyebolt for the actuator rod is way longer then mine. which would leave the door open.
Old Jun 29, 2011 | 11:46 AM
  #254
slatermvp's Avatar
I haven't tried because I haven't fixed the altenator belt yet.
When I broke the belt I was at 85 percent load and it was starting to pull but I didn't see the boost gauge go past "0".
  #255
slatermvp's Avatar
sorry for another request but can you post a pic of your actuator please in the closed position? or is it in your thread?
