Jake's 06 ES Lancer Build
Old May 8, 2012 | 06:02 PM
  #106
jakermeister's Avatar
I need a different definition. It just has the info of the rom. I can't see the maps on the one Burner e-mailed.
Old May 8, 2012 | 06:07 PM
  #107
I can't see the maps below. It didn't ask me which file to inherit either when I opened it up.
[IMG] Uploaded with ImageShack.us[/IMG]
He said to try and inherit another definition. I just need to know how to do that when it doesn't ask you
Old May 9, 2012 | 09:57 AM
  #108
slatermvp's Avatar
Is ur path correct in ECUflash to where you have the definition files?
Old May 9, 2012 | 10:03 AM
  #109
RoadSpike's Avatar
It doesn't look right to me the path should be rommetadata not the folders in it.
Old May 9, 2012 | 11:42 AM
  #110
On the rom file directory or the metadata directory? So just back it out to rommetadata instead of going to mitsubishi/lancer?
Old May 9, 2012 | 11:49 AM
  #111
I backed out to "rommetadata" but still can't see the maps. Burner said he had to inherit a definition for this rom too.
Is that what you meant RoadSpike? back it out to "rommetadata"?
Thanks,
Jake
Old May 9, 2012 | 11:54 AM
  #112
I checked the definition files I downloaded and theres no definition for Burners rom. I need to inherit another definition but it hasn't asked me if I want to inherit another definition. Can I just modify a definition in notepad? If so hopefully the paths are still correct
Old May 9, 2012 | 12:05 PM
  #113
RoadSpike,
Do you know which processor(s) the lancer/ evo ecu's have and how many bits they are?
Old May 9, 2012 | 01:47 PM
  #114
RoadSpike's Avatar
Originally Posted by jakermeister
RoadSpike,
its a 16 bit ecu the number of bytes the rom contains is dependent on the year. I'll assume you don't mean the new ecu's too which are 32 bit processors.
Whats the rom id on this btw is it one i made? You can just grab my definitions from the other forum.
Oh and yes backing it out to rommetadata was what i meant.
Old May 9, 2012 | 04:08 PM
  #115
This is for a stock rom for a 05 Lancer. Burner got his maps to work by inheriting another file from a similar year. His rom is 96630007 (05 Lancer) & mine is 88250010 (06 Lancer). Both are undefined. I don't know how to inherit another definition tho. I was looking possibly buying IDA if I run into some spare change I can't see any maps on both roms. I have a lot of time after work so I thought getting into something more constructive other then playing games online would be better.
Old May 9, 2012 | 08:32 PM
  #116
RoadSpike's Avatar
If you haven't defined it already it should prompt you to create a definition for the rom. If it doesn't that probably means an xml was built and you can just erase it to start again.
It should say something like start new def, inheriet from existing, custom, etc. It should give you a drop down of the options.
I got my "copy" of IDA pro version 5.5 btw from a "questionable" internet source as i'm doing free work i figured free developer tools are needed hah!. Also I recommend decoding a really WELL defined rom like my own or a tephra rom so you can get a feel to what does what by looking at the the defined rom addresses and decoding them.
Old May 9, 2012 | 09:33 PM
  #117
03lances's Avatar
I had a copy of IDA pro, ditto as RS on how I "aqcuired" it lol. I have been looking everywhere for it I thought I had it backed up on a disc but cant seem to find it, nor can I find it on any of my computers hdd. I recently upgraded one of the laptops to win 7 Im wondering if I had it on that and wiped it out when I deleted the partition :-/
Old May 9, 2012 | 10:21 PM
  #118
LOL ok i'm just dipping my toes in to get a feel of what I need to do but I do have a lot of free time. Where would I find and delete the xml that was created? in the rommetadata?
Thanks,
Jake
Old May 10, 2012 | 09:11 AM
  #119
RoadSpike's Avatar
Thanks,
Jake
Yes, usually inside the mitsubishi then lancer folder should be named romid.xml
Old May 10, 2012 | 02:45 PM
  #120
Thanks RoadSpike. I'll look at it when I get off work. I've also was able to get ida pro too
