beastly 2.4 build
Old May 24, 2015 | 01:31 PM
  #106
crf inc.'s Avatar
Its been a while but heres a small teaser of the tube front I'm building. 1 3/4" .120 wall DOM tubing. its all going to tie into a 6 point cage inside when I'm done.
Old May 24, 2015 | 06:55 PM
  #107
jakermeister's Avatar
Pretty sweet build. I went thru the entire thread a few weeks ago and was wondering if you finished.
Old May 25, 2015 | 11:41 AM
  #108
crf inc.'s Avatar
I guess this update answers your question..lol I'm a long way from finished. I think I have decided to fab my own turbo manifold since now I have all the equipment to do so. The possibilities at this point are endless so I guess whenever I can get myself to stop thinking of new ideas I can call it "finished".
Old May 25, 2015 | 02:21 PM
  #109
Pretty awesome build. I'll be watching. I'm online usually every other day.
Old Jun 7, 2015 | 01:03 AM
  #110
doncarbone's Avatar
looking great so far, excited to continue to see this project progress!
Old Oct 20, 2015 | 10:28 AM
  #111
death's Avatar
any updates?
Old Oct 23, 2015 | 05:00 AM
  #112
FTONOOB's Avatar
Hello. Are the KIA heads standing up to the task?
Old Nov 5, 2015 | 10:54 AM
  #113
*02Lancer*'s Avatar
Projects looking good, what are you planning on doing for traction? And as always more pictures!
Old Dec 26, 2015 | 02:27 PM
  #114
crf inc.'s Avatar
Originally Posted by death
any updates?
Just a small one. finished up my front solid engine brace.
havent got to put it up to the task yet so i couldnt tell you! lol
some really big slicks to start out then maybe look into the AWD conversion.
So the reason that ive had so few updates lately is because I have been working on opening a performance fabrication & repair shop out at Willow Springs International Raceway. Been open a few months now but we havent actually had our grand opening. Anyone is welcome to come check us out or just stop by to say hello!
Here is a link with some pictures.
https://www.evolutionm.net/forums/we...on-repair.html
Old Jul 23, 2016 | 10:41 AM
  #115
crf inc.'s Avatar
Update!
I decided to put in a little work on the lancer in the last few days. Finished up a lot of the tube chassis front end. I'm pretty happy with the way it turned out.
Old Jul 31, 2016 | 04:00 PM
  #116
kjsperformace's Avatar
Do u build the front end tubed chassis and sale them
Old Aug 1, 2016 | 11:57 PM
  #117
crf inc.'s Avatar
Yes I do sell ten as well as build them. Something like this tube chassis front would run between $1000-$1500. I also build full roll cages, build performance engines and do body modification. I just got my resale license as well so I plan on becoming a licensed dealer of aftermarket performance parts. Give me a call if you have any questions. 661-609-4386
Old Aug 2, 2016 | 10:17 AM
  #118
Ok I will call u shortly when I get the money I need a tubed front end for a 2002 lancer oz rally
Old Aug 2, 2016 | 11:11 AM
  #119
spdracr83's Avatar
nice build but a little FYI
the sonata head combustion chamber measures out to 45cc unlike the false information available around the internet claiming it was measured to be 55cc which would lower the compression as you have previously stated. both the heads i own came out to exactly 45cc and used that calculate my desired CR on my build.
as far as using stock cam gears, u r about a half a tooth or so off, it will not line up perfectly due to the change in deck height so an adjustable cam gear will get u dead on while stock gears will be off a bit.
heres my first start-up video with the sonata head and fully built bottom end.
this link has all the engine specs.
https://www.evolutionm.net/forums/pr...ega-beige.html
Old Aug 3, 2016 | 11:18 AM
  #120
crf inc.'s Avatar
Thanks for the info. So essentially what your saying is that I'll be running 9:1 compression ratio because the heads are both 45cc? I am completely ok with that as it just means I will be able to make more power on less boost. I guess I should have measured the heads cc's! Lol and thanks for the heads up about the cam gears, I was already aware of that and the stock Evo cam gears were only for mock up an the initial start up. I definitely plan on getting adjustable cam gears before running the car on the track. 👍🏻
