NEED HELP FAST!!! just bought 2 alpine 12" R's + I NEED AN ALPINE AMP TOO!!!
Originally Posted by Zippo41189
yea, so feel free to jack my thread as necessary please
. or atleast maybe have some common courtesy to say "hey, sorry for the OT real quick, but..."
anyway, It has good output, but i think it would blow the R's eventually b/c they are only rated to 1,500 a piece and that is 3200 right? I think it lacks quality too...
ok, I just bought...
THIS!...
...THIS...
and THIS!
now, I know I need speaker wire and what else now? also, I would love to do 0/1 gauge, but are u sure my alpine HU/amp/subs can take the 0 gauge or is it too big? or will I be ok with it fitting? HELP!
also, I was thinking of a completely Plexiglass box so I can show ff the R's from more than the front. what do u all think and should I buy a box or make it?
THIS!...
...THIS...
and THIS!
Thank You
~Merc~
^If you followed the thread, we're past that, but I'm not going to argue with you.
any advice of speaker wire, power wire, and remote wire? gauges and lengths?
I followed the thread, and I know you purchased the amp...I was asking about another amp(on topic) but yea not worth arguing over, life's too short
seriously just go to an audio shop and get a kit, or maybe ebay...its the terminal, power wire, ground wire(theyre both the same just diff color) and the remote wire(its just like a 16gauge wire that runs from the cd player or switch). It also comes with oxygen free rca cables as well and power/ground wires
You could just go big and get 1/0 gauge wire.
seriously just go to an audio shop and get a kit, or maybe ebay...its the terminal, power wire, ground wire(theyre both the same just diff color) and the remote wire(its just like a 16gauge wire that runs from the cd player or switch). It also comes with oxygen free rca cables as well and power/ground wires You could just go big and get 1/0 gauge wire.
wellllllllllllllllll thennnnnnnnnnnnnnnnnn :P cranky arnt we
j/p
anyway
for that amp, 4 guage wire will work or you can be a big man and got 1/0 but its not needed
id get 20 feet of power wire and 5 feet of ground (on the safe side)
just depends how long your going
15 feet of remote wire is fine, and its like size 26-28 (cant remember) not 16 :P thatd be some big turn on wire
j/p
anyway
I really don't/didn't care, it was just abrupt i guess.
I've been getting cables off ebay and only need speaker, remote, and power wires left I guess. After that, on to a box is the last step... hopefully I'll have all the wires ordered/in by tomorrow so I can move on to selecting that bad boy. almost done!...
Originally Posted by ThunderOZRacer
hey would an audiobahn A2200HCT be good enough to run two Type R's?
my advice on speaker cable is 2 run the shortest/thickest combo possible. on power cables, 16gauge remote turn-on is good but double the thickness of power cable for every 1000 watts of power. 4gauge is good up to 1000 watts RMS to your d-block w/8 gauge to the amps. over 1000 watts, go with 0/1gauge to the d-block & 4gauge to the amps...
This one.. This... and THIS! to add to the collection. so now all I need is a box right!!??!?! I'm so close!!!
looks good... i like the name of the stuff, expert series and pro series :P there really isnt a diffrence but it sounds good
remote turn on wire just does what it says .. turns on your amp, nothing special you did good with that price though
^sweet thanks bene... you've really gotten me through this more than anything; I couldn't have gotten this far without ur help. All thast left is the box, which is hard b/c 1. I have strut bars in my rear and 2. I kinda wanted to put my amp inbetween the 2 subs to show it off. I'm still lookin...
^Great! The idea I have thus far is for it to go in the far back of my trunk, ON TOP of my strut bar. I plan on doing this by cutting a notch/slit in the bottom of the box and then closing this off to make an upside-down "U" shape over my strut bar. This way, I will have more trunk space and a tighter fit with less chance of the box sliding around.
For the box itself, I really only need the standard box. I'm thinking slanted sub and amp rack so the 12's aren't pointing directly outward, but have an incline to them so they point "UP" a few degrees with, if possible, an amp rack in the middle. I don't know if it will all fit that way b/c the subs are 25"+ the 14" amp and I only have about 38" from strut-to-strut in the trunk. So I'm guessing I will have to put the amp on top of the box? plus the subs are almost 8" long, so I'll have to make sure they clear the "notch" in the box b/c of the angle the magnets will be facing closer to the bottom of the box. LMK if we can work with this?! Thanks!
