my ebrake & battery lights flash w/my bass...
Old Oct 7, 2002 | 09:40 AM
slightlyshady1's Avatar
Question my ebrake & battery lights flash w/my bass...
i was drivin home 2nite n all of a sudden the ebrake n battery warning lights started flashing along w/the bass from my subs...now wtf do i do? jus leav it?
Old Oct 7, 2002 | 09:42 AM
pisetup's Avatar
I would say, if it happens again take it back to the dealer and have them check it out.
Old Oct 7, 2002 | 09:46 AM
pjal84's Avatar
Sounds like you've got a fuse problem or a wire touching another wire when the bass hits just right...strange.
Old Oct 7, 2002 | 01:15 PM
ancer06's Avatar
hm.......
if you have that much bass going on, you could use a cap (capacitor) on your amp and that might prevent the clichts from flashing.....i dunno about the e-brake light tho, that is kinda weird.
Old Oct 7, 2002 | 01:16 PM
ancer06's Avatar
typo
clichts = lights....its kinda late sorry
Old Oct 8, 2002 | 01:32 AM
i found a fuse on the floor 2day so im gonna put that bak in lata n c if that makes it stop...i hope...
Old Oct 9, 2002 | 12:10 AM
yannotmi's Avatar
Shady
It depends on the amount of juice your amp is taking and how you have it wired. If you have a couple of Subs wired in parallel it will drop the inpediance of the amp and make it work harder, requiring more juice from the alternator. When this happens everything electircal suffers; AC, windows, lights.....
A cap may help but you may need to look into a beefy alternator.
Suggestion.....
http://www.termpro.com/articles/spkrz.html
Old Oct 9, 2002 | 12:25 AM
SpeshalK's Avatar
I wouldnt try a alternator, unless you were going to go compete.....if its just a small electrical problem like ur headlights dimming out than a capictor could be useful, in your case though if lights are coming on and stuff, Id say you have a big problem, rca cable touching something else......go through and follow all your lines and see if they are safe
Old Oct 9, 2002 | 01:38 AM
yannotmi's Avatar
SpeshalK has a good point too, it may be a faulty wiring job. To make indicator lights turn off/on means that it could be a major short in the system. Check your power and ground....
One thing about caps and electricity.
A capaciator only holds and releases energy. It is a fast acting depository that works well with amplifiers because it can feed the amplifier a lot of energy when it peaks, in milliseconds...
A cap will only band-aid the issue, not fix it. Any time you add electronic components to a car, you are adding a load to the alternator. Car manufacturers only put in parts to do the job of the car, not extras, especially an amplifier.
Stock alternator only has 85 Amps , which is nothing to brag about.
Stock Alternator
Old Oct 9, 2002 | 03:08 AM
ok...now the warning lights come on for a few seconds wen i accelerate and then sometimes just randomly blink!!!! Im 99% sure this all started wen i put my intake in on sun nite BUT it could hav started fri wen the fuse fell out as i hadnt done much driving btween fri nite n sun wen i put the intake in
o PS it doesnt flash along w/the bass anymore...
so any new suggestions???
Old Oct 9, 2002 | 03:36 AM
Pimpson's Avatar
follow the previous suggestions and retrace the wiring. disconnect the amp to isolate the problem. Then follow basic troubleshooting techniques. Divide and conquer by making sure one piece isn't the problem and eliminating it until you find the cause.
Old Oct 9, 2002 | 03:40 AM
YellowOZLancer's Avatar
i got a suggestion, turn it down man but seriously i would prob invest in a capacitor and follow previous suggestions.....
Old Oct 9, 2002 | 04:06 AM
i dont think its the amp cuz it does it wen the radio is off now 2...wen i hav time i'll get in there n fully check out ALL the wires and figure out how 2 get that fuse bak in, thanx guys
myra13
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 16, 2017 07:26 PM
CaptainCrunch
Jun 23, 2016 08:16 PM
[GBU]Moon
11
Apr 29, 2016 06:23 AM
BRalliart
Aug 22, 2015 08:01 AM
OZ_03
14
Nov 26, 2003 04:37 PM
