ROAD/RACE Piggyback VERSION 2
Old Sep 12, 2005 | 10:29 PM
  #211
Boeturbolancer's Avatar
yes it can run on higher octane just fine... required to be at least 89 though.
Old Sep 13, 2005 | 08:45 AM
  #212
drucea's Avatar
ok thanks boe, i'll get pics today and get them sent in.
Old Sep 13, 2005 | 11:42 AM
  #213
drucea's Avatar
hey rock, i sent you some pics in an email. you should be able to see which wires are connected where, and how they are connected.
Old Sep 13, 2005 | 12:36 PM
  #214
02OZR's Avatar
Thumbs up
any word on the 02-03 shippment?
Old Sep 13, 2005 | 01:15 PM
  #215
i believe some went out yesterday... the rest are on their way today. Shouldn't be long now.
Old Sep 13, 2005 | 03:50 PM
  #216
noriceoz's Avatar
i want mine so bad so i can take back the ohio area back from the ricers
Old Sep 13, 2005 | 04:40 PM
  #217
drucea's Avatar
Success!...kind of, i rdid the learning part again, the CEL did not come on, but its still misfiring. is idle at 500-700 rpms low? cause if so then that migh be the problem cause thats where it idles
  #218
Z_Lancer_Man's Avatar
^^ Nice motivation I want mine cuz I need more power!
Old Sep 13, 2005 | 04:45 PM
  #219
Johns Slow ES's Avatar
Thanks for the reply Boe I am installing the PB now let u knoe if i run into any problems thanks
Old Sep 13, 2005 | 04:50 PM
  #220
drucea's Avatar
yeah post how it goes after you get it up and running. i wanna know if yours does the same things. i cant wait to get mine worked out so i can see how it really does. it feels like its got lots more pull with it misfiring, will it be better once that is fixed?
Old Sep 13, 2005 | 07:03 PM
  #221
ROCK's Avatar
Like I said, raise the idle 200 rpm in park. That should help. This setup has proved bullet proof so it is either install issue or, install issue. Gabe will be awaiting your call. I forwarded pics to him. 02-03 shipped today.
ROAD/RACE
Old Sep 13, 2005 | 07:08 PM
  #222
drucea's Avatar
ok thanks, yeah i'll go try raising the idle, i figured that might be the problem cause it only kicks in park or at idle.
Old Sep 13, 2005 | 07:58 PM
  #223
ROCK's Avatar
Could have sworn I told you to do that already. Did I?
ROAD/RACE
Old Sep 13, 2005 | 08:12 PM
  #224
Originally Posted by ROCK
I think it is a something else. We always assume everything is healthy but it sounds like you may not be. Regardless. Rest ECU by disconnect the battery. Drive the car easy for a day. When you first start the car the first time let it idle for 10-15 minutes. Let ECU learn a bit. CEL may not come back. Also if idle is a little jumpy on automatic, rasie idle at t.b. 100 rpms in park. That should solve it all for you. Duble check your connections too.
ROAD/RACE
Yup, you sure did.
Old Sep 13, 2005 | 08:25 PM
  #225
FlipBoiFlava242's Avatar
wow just went through the whole 15 pages of posts. this is really exciting! especially since it can run offa 89 octane. I can't wait to see the results. maybe i'll be aimin for this once i get back on the whole modding thing..for now...just another broke college kid . it's always nice to dream though . Much props to RRM!
