EcuFlash Definition File Master List
Old Feb 6, 2010 | 04:56 PM
  #151
bluelancer20028's Avatar
86640015 2005 lancer es auto i updated the files earlier today and dl the rom from car and it still looked the same as it did earlier this week
Old Feb 6, 2010 | 05:32 PM
  #152
4g94T's Avatar
Senate,
Is there any way you can add the 'Start up Enrichment IPW Adder' table for my ROM?
during cold starts the car starts up fine, but when the motor has warmed up it is difficult to start.
It requires me to give it some gas in order to start up. Kinda annoying...
Old Feb 6, 2010 | 05:43 PM
  #153
senate6268's Avatar
Originally Posted by 4g94T
Senate,
I've stopped working on Lancer ROMs for the most part now that I'm running an Evo ECU. Sorry.
Old Feb 6, 2010 | 05:44 PM
  #154
senate6268's Avatar
I had someone email me a 86640015 ROM to expand the definition file. It looked fine for the most post when I finished with the definition file. What are you having issues with?
Old Feb 6, 2010 | 07:18 PM
  #155
i sent you that the maps are good but the load values and rpm on the side is all over the place if i could get a evo ecu i would probally just do that lol
Old Feb 6, 2010 | 07:54 PM
  #156
senate6268's Avatar
I just re-opened the 86640015 ROM I have a copy of and the axis values are fine on all of the tables. Are you using the correct endian values appropriate to the version of EcuFlash you are using?
Old Feb 7, 2010 | 09:09 AM
  #157
im using 1.42 thats y i was wondering if i need to reinstall openecu b/c when i dl my rom the first time i inheritted i guess from the other definition so i was wondering if openecu will always gonna remember that or there is something i can do w/out reinstalling
Old Feb 7, 2010 | 09:50 AM
  #158
senate6268's Avatar
If you have a definition file for your ROM then it shouldn't be inheriting from other files. Are you certain that your ROM is 86640015? You can check for sure by looking at your ROM in a hex editor, starting at F52.
Old Feb 9, 2010 | 10:38 PM
  #159
i reinstalled everything and all the tables a perfect thanks senate for all you have done
Old Feb 10, 2010 | 08:04 AM
  #160
08:59:28.828] Using interface OpenPort 1.3 Universal TX27XeHm39c1f4d53c43cca6c18bdebbdf14777d4bf1c331
[08:59:31.812] sending init sequence 1 (0003)
[08:59:32.843] got 0x05 response
[08:59:32.843] sending init sequence 2
[08:59:32.859] got 0x1B response
[08:59:32.859] sending init sequence 3
[08:59:33.234] entering bootloader
[08:59:33.250] sending kernel size (4420)
[08:59:33.281] sending kernel load address (0xFFFF7000)
[08:59:33.296] uploading kernel
[08:59:34.015] verifying kernel checksum response
[08:59:34.015] kernel valid
[08:59:34.234] kernel get version
[08:59:34.234] rkrv: preamble 1 error
[08:59:34.250] reading kernel comm buffer size
[08:59:34.468] reading kernel flash buffer size
[08:59:34.687] interface close
this is what i get now when trying to reflash any insight???
Old Feb 10, 2010 | 06:18 PM
  #161
senate6268's Avatar
Are you able to read the ECU? Since you ended up doing a reinstall, you might have a driver issue. Also, verify that your key is in the "On" position, but that the engine is NOT running. What version of EcuFlash are you currently running?
Old Feb 10, 2010 | 07:16 PM
  #162
yea i can dl rom yea i did eveything right im running 1.42 and when you go to dl rom it will not let me do 2001-2005 option i have to pic 2006 option but not the 2006+ can
Old Feb 10, 2010 | 07:54 PM
  #163
senate6268's Avatar
Ah. Run a version between 1.31 and 1.41. I've not been able to use v1.42 with success either. I use a combination of 1.29 in a VM and 1.41 in Win7.
Old Feb 10, 2010 | 08:02 PM
  #164
where can i get that version i have looked all over and cannt find it
Old Feb 10, 2010 | 08:18 PM
  #165
senate6268's Avatar
Here's v1.41: http://www.4shared.com/file/21095106...12483_win.html
