Lean under boost!!
Old Dec 12, 2008 | 03:43 PM
  #136
4g94T's Avatar
Originally Posted by TouringBubble
If STFT is + you increase the MAF value. You have to keep airflow steady for a few seconds for accurate readings though. For LTFT, the low trim reflects values under 100hz and mid trim is 100hz to 500 hz.
+ means the ECU is adding fuel and increasing the MAF value lets the ECU know that there is more air than it's expecting.
If you're going lean at WOT, increase the MAF values in that hz range.
Divide the left column in the MAF scaling table by 10 to get the hz value. The last cell, 16XXX is 1600 hz.
so are we leaving the MAF Size alone?
Old Dec 12, 2008 | 05:47 PM
  #137
Complink's Avatar
yes
Old Dec 12, 2008 | 09:37 PM
  #138
sykou's Avatar
Ya i just changed my maf table axis cuz my values were wack. Left the size alone
Old Dec 15, 2008 | 09:24 PM
  #139
4g94T's Avatar
So whats everyone using for injector scaling and latency for the 440cc injectors?
I can't get mine to idle at 14.7 it's too lean around 18.0-19.0 AFR
Old Dec 15, 2008 | 09:31 PM
  #140
sykou's Avatar
I.m using the stock latency
But my idle is rough too. Curious...
Old Dec 15, 2008 | 09:42 PM
  #141
4g94T's Avatar
What is your AfR at idle?
So your injector scaling is stock also?
Old Dec 15, 2008 | 10:49 PM
  #142
sykou's Avatar
afr is around 14.7ish at idle but heres the thing. I have 210 as my injector scaling, stock latencies, and using a eclipse maf plate
Old Dec 15, 2008 | 10:55 PM
  #143
4g94T's Avatar
hmm isn't stock scaling 232?
I'll play with the latencies in the morning and see what I'll get.
Old Dec 16, 2008 | 11:48 AM
  #144
TouringBubble's Avatar
I'm working on a car right now with the 440's and I'm trying out the stock WRX latencies and scaling as a starting point. We'll see how it goes. I'll report back.
About the MAF scaling ... I've got the injectors dialed in on one car and we should have WOT logs in the next couple of days. Waiting on the other as it's the same car with the 440's mentioned above.
I've got a problematic Evo at the house as well that has idle issues after cams. It's definitely related to MAF readings so I'll likely learn much more about the different settings as I troubleshoot that car more.
Old Dec 16, 2008 | 03:18 PM
  #145
4g94T's Avatar
is there any way we can add fuel during cold starts?
i know evo ROMs have cold start enrichment tables.
I richened the fuel map in the idle areas but it only affects idle during normal operating temps.
Old Dec 16, 2008 | 04:00 PM
  #146
sykou's Avatar
Id like to know that too. With the cams the starter struggles to start her up
Old Dec 16, 2008 | 07:58 PM
  #147
4g94T's Avatar
yea i want my AFR to be at 14.0 on cold start, its at 15.0 AFR right now =/
Old Dec 16, 2008 | 11:23 PM
  #148
sykou's Avatar
mines is usually around 14ish hot or cold start but i have to blip the throttle to start her up. Would help if we could dump more fuel in on startup to simulate this throttle "blipping"
Old Dec 17, 2008 | 10:24 AM
  #149
There is a table, but it's not defined. I don't do disassembly so I can't find it myself. It's basically a fuel modifier for start up.
You could always tune the injector latencies for more/less fuel during cranking ... just note the voltages and adjust the latencies in that range.
the car will idle in open loop until it reaches a certain temp ... adjusting the map will help the issue in that range. Once it's closed loop there is nothign you can do. You can however lower the crossover value at your idle RPM (Open Loop Load map) to force an open loop idle and then just dial in the fuel map and idle stepper values to your liking.
Old Dec 18, 2008 | 06:10 AM
  #150
I reviewed logs last night and found promising results. The issue seems to begin around 500hz airflow, so that is where the changes need to be made. When I get a solid map I'll post it for you all.
