Lean under boost!!
Old Dec 2, 2008 | 05:47 PM
  #46
Complink's Avatar
here is my before(left) and after(right) of my maf scaling
Old Dec 2, 2008 | 06:12 PM
  #47
4g94T's Avatar
so would you need to increase the MAF scaling values more to have more fuel under WOT?
does it affect open loop fueling?
Old Dec 2, 2008 | 06:27 PM
  #48
Complink's Avatar
1. yes you would increase the values to increase fuel.
2. yes and no. if you increase after 500 hz then it will only affect open loop since you will rarely hit more than 500 hz and still be in closed loop. anything below that and its possible it will affect closed loop cruise and idle(but will just be corrected for with LTFT).
you can actually tune your idle and cruise this way if you compare your trims at a certain hz flow
Old Dec 2, 2008 | 07:15 PM
  #49
4g94T's Avatar
alright... now i hope i can get someone to define MAF scaling in my ROM so i can try this out
Old Dec 2, 2008 | 07:38 PM
  #50
senate6268's Avatar
Christmas came early. Check out the master definition list thread. I was able to define the Y-axis values for the definition file you use. Cheers.
Old Dec 2, 2008 | 08:20 PM
  #51
Complink's Avatar
Thank you senate claus!!! lol
  #52
4g94T's Avatar
Woot! Thanks for the present!
Complink, did you notice if your load values increased after increasing MAF scaling?
Old Dec 2, 2008 | 08:24 PM
  #53
Complink's Avatar
actually i was just looking at my wideband. i didn't log it cuz my laptop battery sucks and i need a new one
Old Dec 2, 2008 | 08:36 PM
  #54
4g94T's Avatar
haha my laptop sucks PERIOD.
i keep mine connected in the 12v otherwise it'll die in 10 min
the only thing that keeps me from throwing it at the wall is its the only thing i can use to tune my car
Old Dec 2, 2008 | 09:40 PM
  #55
Complink's Avatar
lol
Old Dec 2, 2008 | 10:10 PM
  #56
4g94T's Avatar
hmm... so i downloaded the new definition files and put them under the rommetdata folder, but i still dont see MAF scaling?
am i missing something here?
Old Dec 2, 2008 | 10:21 PM
  #57
sykou's Avatar
hey defining the maf scaling y axis... you follow the maf scaling tutorial right? define the y axis to show airflow in hertz and then some other stuff right? I got the tutorial on my other computer...
Old Dec 2, 2008 | 10:23 PM
  #58
sykou's Avatar
oh ya and logging the airflow hertz... what do you use? Evoscan has airflow i believe but is it accurate?
Old Dec 2, 2008 | 10:27 PM
  #59
4g94T's Avatar
mitsulogger logs airflow in hz.
so what should i do, i opened up ecuflash and i dont see MAF scaling still...
Old Dec 2, 2008 | 10:35 PM
  #60
sykou's Avatar
Ya if its not showing up then its not defined in your def file...
