Lean under boost!!
Old Dec 6, 2008 | 11:56 AM
  #106
4g94T's Avatar
Same thing, I threw the P0300 =\
Old Dec 6, 2008 | 01:11 PM
  #107
senate6268's Avatar
Originally Posted by 4g94T
You blew the RPW decomp head gasket?
That thing is rated up to 15 PSI I think
I hope the stock one can withstand 10 PSI
The RPW decomp is good to 18psi. The stock headgasket will hold up fine to high levels of boost as long as you have ARP head studs. The RPW gasket is composite and is prone to failure under boost. There are threads on other sites that talk about this.
Old Dec 6, 2008 | 04:33 PM
  #108
4g94T's Avatar
Instead of p0300 during WOT I now get p0304 which is cylinder 4 misfire.
And my car is back to going lean again! It starts off at high 10 AFR and as the boost and RPM rise it tapers to low 12s AFR.
Did anyone else solve the lean issue yet?
Old Dec 6, 2008 | 05:04 PM
  #109
Complink's Avatar
i did. im now hitting 9-10 psi and my afr is around 11.5. i ended up having to max out the maf scaling at 800,900, and 1000. does your boost rise with the increase in afr? i noticed before that i would hit about 8 psi at 12.5afr, and then when i increased the amount of fuel to under 11afr, my psi dropped to about 6.5. so i think the leaner you get the higher your boost will be (almost like a runaway reaction). i would just try to increase the scaling more at 800-1000 hz.
Old Dec 6, 2008 | 05:35 PM
  #110
4g94T's Avatar
What are your values in the fuel map? All 10.0?
So all you touched where the values in the MAF scaling?
Nothing else?
Old Dec 6, 2008 | 10:15 PM
  #111
Complink's Avatar
my values go as low as 9.5
that is correct.
Old Dec 6, 2008 | 10:52 PM
  #112
sykou's Avatar
what kind of boost controller you running... sounds like that could be causing your variations in boost...
Old Dec 7, 2008 | 12:29 AM
  #113
4g94T's Avatar
Hallman MBC, it's consistent with little to none boost creep.
I think my injector on cylinder 4 is going bad.
I'm gonna switch it to another cylinder and see if the misfire will switch.
I need bigger injectors anyways...
Old Dec 7, 2008 | 10:22 AM
  #114
Complink's Avatar
are you using stock fuel pressure or running a fmu?
Old Dec 7, 2008 | 10:33 AM
  #115
4g94T's Avatar
stock fuel pressure...
anyone know where to get wrx 440cc injectors?
Old Dec 7, 2008 | 10:42 AM
  #116
Complink's Avatar
i found mine on ebay for around 100 used
Old Dec 7, 2008 | 11:08 AM
  #117
sykou's Avatar
Check on nasioc forums... Your boost shouldn.t vary like yours does... Might wanna check for a vac leak on the charge side post turbo
Old Dec 7, 2008 | 11:22 AM
  #118
4g94T's Avatar
will 05 WRX injectors fit?
someone is selling them on NASIOC
Old Dec 7, 2008 | 09:08 PM
  #119
sykou's Avatar
get a pic of them... They are gonna be light blue in color. From the 2002-2005 WRX 2.0L engine
Old Dec 7, 2008 | 10:59 PM
  #120
4g94T's Avatar
they're from an 05 WRX
