Evo 8 ECU Swap Works!!!
You make a good point, Cmon guys if people dont start why should he even post this for our benefit? If its any consolation I already have my ecu but wont put it in till my turbo goes in.
I'm not trying to down your work I'm just trying to figure out why I cant get it to work, im in the process of trying it right now , I swapped the wires and took a 96510009 eclipse ecu.. I tried using evo rom 94170008 flashed into the ecu that is what the eclipse guys do. evoscan also reads the ecu . and give readings for different sensors.
96510009
I get p0100 , p1610 , p0108
94170008
I get p0113 , p0108
both are giving no start situation.
96510009
94170008
I get p0113 , p0108
96510009
94170008
I get p0113 , p0108
96510009
94170008
I get p0113 , p0108
Those codes are for Immobilizer, IAT, MAP and MAF sensors. Those 3 sensors are some of the pinout differences between the 4G64 and 4G94 according to the FSM diagrams for both.
I got my ecu for $100 shipped and its out of an 05 evo I would imagine this should work great!!! I am so excited to get the rest of my parts the only thing holding me back is I am getting married in Oct and so that is giving my wallet a hell of a beating...
I bought my 04 Evo 8 ecu for 125 shipped, I don't have a tactrix cable yet, but I did just go to a bunch of local muffler shops to find a quote on welding the flange to the manifold, and I found a good shop down the street to weld it for 50 bucks! Then I need oil lines, and the tactrix and I will do the install, and swap ecus! I am sure I will have plenty of questions when I get there!
All of your hard work is really appreciated, and def glad you shared it all with us! Thanks senate! You guru you!
Ok so a little off topic but just a little.. so having the ecuflash mitsulogger and evo8 ecu, fuel pump and 440cc injectors means I DO NOT need fmu OR adjustable fpr or do I?
