Evo 8 ECU Swap Works!!!
Old Sep 26, 2009 | 03:42 PM
  #121
senate6268's Avatar
Originally Posted by *02Lancer*
I will want the information on how to get it but first i have to find a dang ecu :P they all sold! lol
Pin 43 on the Evo ECU is the CLUTCH SWITCH INPUT. This input is triggered when the clutch is depressed, causing the ECU to reference the Stationary Rev Limit seen in EcuFlash. The Stationary Rev Limit value in EcuFlash is referenced only when the clutch is depressed, not when the car is not moving or in neutral.
A signal wire coming from Pin 2 on the clutch switch needs to be ran to Pin 43 on the ECU harness. I believe there is an EvoM member in the EcuFlash threads that sells pins for adding extra wires to the ECU harness. I can't recall who off the top of my head.
Old Sep 26, 2009 | 10:22 PM
  #122
vityenyka05's Avatar
SWEET.. senate6268 IS SO MUCH HELP.. I'VE JUST READ THE WHOLE THREAD FROM BEGGINING TO END, ITS LIKE A BOOK. LOL ANYTHING NEW WITH THE ESU, I'VE JUST BOUGHT ONE FROM AN EVO 8 2005.. WOLD LOVE TO GET SOME HELP..
Old Sep 27, 2009 | 08:52 AM
  #123
*02Lancer*'s Avatar
AHH were you get it! lol
Old Oct 2, 2009 | 05:53 PM
  #124
ClixT's Avatar
question, will this pass SMOG?
Old Oct 2, 2009 | 06:02 PM
  #125
darkmitsu's Avatar
yes
Old Nov 2, 2009 | 02:13 PM
  #126
steven121's Avatar
evo 8 ecu questions
ok if the evo 8 ecu works for the lancer, do I need a fuel management system, I called road race and they said I needed a standalon system. I need help on just this part of turboing my car.
If i get the evo 8 ecu
440 cc injectors
will this be my fuel management system?
and do I need to replace the maf sensor on my car to make this work?
I have a TD05HR 16G 9.8 T turbo. Please help!!!
Old Nov 2, 2009 | 02:17 PM
  #127
03lances's Avatar
I have a 16g and I will be using 440's and a walbro 255 you will need to upgrade your fuel pump. I have a evo 8 ecu but to start my tuning I will be using the stock ecu with rescaled load values
Old Nov 2, 2009 | 04:37 PM
  #128
run1206's Avatar
440 cc injectors
i might do the same setup on my Galant; i think you might mave to use the MAF Translator built for an evo 8, not too sure though
Old Nov 3, 2009 | 12:39 PM
  #129
steven121's Avatar
Yeah thats what I heard to, but the only problem is trying to find an evo from a scrap yard. anybody know where you can find a maf sensor?
Oh if you need an evo 8 ecu I know this place that sells them and they do the tuning for like $99.00 call speed innovations! 1-800-773-8656
if they don't have the special anymore tell them that Steven J refered you to them and they should give it to you. So all I need is the maf sensor and I should be good
Old Nov 3, 2009 | 02:59 PM
  #130
steven121's Avatar
Hey Guess what I just found out, if you have a 4g94 or 4g93 motor the 4g63 head will fit on those blocks with a few modifications. So I think im just going to do that instead. The guy I spoke to said once you do that its like having an evo 8, plus you get all the modifications that an evo 8 will require. This is freaking bad ***
Old Nov 3, 2009 | 03:04 PM
  #131
zulu989's Avatar
huh
Old Nov 3, 2009 | 03:46 PM
  #132
JRR's Avatar
JRR
Originally Posted by zulu989
huh
^^+1
Old Nov 3, 2009 | 03:50 PM
  #133
zulu989's Avatar
Originally Posted by JRR
^^+1
are u confused like i am lol, i dont quite get the pc lingo sometimes lol.
is he saying a evo head fits our block or a dsm head
Old Nov 3, 2009 | 03:52 PM
  #134
run1206's Avatar
I already bought an evo 8 ecu from bertune here.
i'll check out that tuning company, thanks for the number
Old Nov 3, 2009 | 04:21 PM
  #135
JRR's Avatar
JRR
any way i look at it im . i didnt think any 63/64 head fit our cars
