Confirmed: Evo ROM Can Be Flashed to Lancer ECU
thanks RS
logging? with evoscan? like i said, still a newb when it comes to this.
using ecuflash 1.42. i dont know what alot of the stuff actually means and what i should be playing with. shift times and pressure, high and low octane maps, etc
Shin you'll want to use my latest patch the old one had issues.
You remember that you just need to change the flashing method in the xml and it will work fine.
Here's the rom:
http://www.megaupload.com/?d=A8T5AM6R
XML:
Here's the rom:
XML:
The launch maps is simply speed and TPS based so it would only be activated when at a standstill and flooring it. The idea behind it is to increase boost by dropping the timing when the rpms are bouncing on the 2step. Its similiar to a semi antilag setup. Once the car surpasses 5mph it cuts over to the regular timing map.
All that needs to be done to run it is enable it for the regular tephra patches.
The shift pressures aren't not super well defined as i stole them off a GTA rom. I think the 1-4 gears are right but the 5th gear one looks like its off so don't try it :P.
Up shift pressure and decrease shift time down to 20 and it should shift hard and fast like a GTR or something. You can just up shift pressure until it feels like its too violent.
I think the octane maps you should adjust both no one knows if the car only uses the low octane one only or not. Since you have a different MAF you'll need to fix that as the stock maf settings are for a stock AT lancer.
Log with evoscan or mitsulogger whatever floats your boat. The load you want to track is 1byte just remember that 2byte doesn't exist on that rom.
decrease shift time to 20 across the board? for shift times 1-2, 2-3 and 3-4? visual aid anyone?
2 step your car and log what load and rpm it bounces at and lower the timing down there really low like -5 degrees that will build boost when 2stepping a lot faster.
I'm surprised honestly your thinking about it as this would definitely give you more traction issues at launch.
i flashed the latest rom 882.. to my ecu. changed settings for the MAF and Injector scaling. let it idle til the shaking stopped then i had it idling for about 5min at 1500 with my foot on the pedal. soon as released it stalled and wont even idle now...
You i hope modified the maf size as well.
You've tasked yourself with something fairly advanced for a starting point.
