Pricing on the Quad Trottle body??
Old Jan 12, 2003 | 11:09 AM
  #31
hardcoretuner's Avatar
i much like ratboy will be ordering these as soon as i can i want to know what i need to do to the motor before i put them in to see the best gains
i already know i need...
stage 2 cams at least
cam gear - questionable
header
exhaust
fuel pressure regulator
aftermarket ecu, haltec
Old Jan 13, 2003 | 07:21 PM
  #32
Mitsiman's Avatar
The qauds yes provide unlimited / controlled air flow into motor hence why they work.
You need with qadus two things on the extractors / headers
(A) You need a tuned length equal runners because remember qauds provide equal amounts of air to the cylinders due to individual runners. This means anything other than tuned length runners will create unequal induction pulsing and unequal power from the cylinders.
(B) Qauds produce lots of midrange and top end horsepower so you need very long primary pipe equal tuned length extractors to maximise torque at lower rpm levels to retain any driveability with qauds.
This was the main first reason why we designed our race series extractors for qaud appliations and then found they wer even more succesful on the normal single throttle boy model cars
Stage 3 cams will work with the non qaud motor but you must have the compute rsystem fitted firt to make them run properly and will still have a power improvement with the other mods done first.
No yuo couldn't run qauds + 100shot of nitrous at the same time on Hyperuetectic pistons - the nitrous would smash them up too quickly. Max of 50 / 75hp nitrous wet system
11.5 : 1 CR with pump gas would be touchy but possible with good tuning.
boostx
Apr 20, 2015 03:06 AM
Kami Speed
41
Sep 28, 2010 01:27 PM
nobullevovii
15
May 16, 2006 06:27 PM
Static
Lancer Engine Tech
15
May 3, 2004 05:40 PM
lanceroz84
Lancer Engine Tech
100
Nov 14, 2002 04:33 PM
