Fuel Filter location
Old Aug 8, 2005 | 12:10 PM
davids2004's Avatar
Where is the fuel filter located at on the 04 Lancer ES Automatic.
Old Aug 8, 2005 | 12:14 PM
blaze_125's Avatar
Should be the same place as the 02-03. Under your rear-seat you'll see a black plate. Remove the plate and now you see the fuel pump. Lift the fuel pump and now you see some sort of tea bag. That's it. There is your filter
Old Aug 8, 2005 | 12:16 PM
SIMSSEGA's Avatar
I think is just comes off of the fuel pump. I know im my 02 that would be under the rear seat, under alittle black square piece of metal that you just need to unbolt and then you can see everything but i dont know how the fuel system changed from the 02's to the 04's.
Old Aug 8, 2005 | 12:25 PM
davids2004's Avatar
So your saying remove the bench part of the seat and remove the black square and then you will just be able to pull the fuel pump out or will you have to unbolt it as well. Someone said my fuel filter could be clogged and causing my bad gas mileage so I may replace it.
Old Aug 8, 2005 | 12:39 PM
SIMSSEGA's Avatar
heres the how to for the gsx fuel pump swap it will give you pics and a step by step on how to take everything apart. Enjoy and hope it helps
https://www.evolutionm.net/forums/sh...ad.php?t=22987
Old Aug 8, 2005 | 12:40 PM
blaze_125's Avatar
Looks like Simssega beat me to it
Old Aug 8, 2005 | 01:48 PM
HobieKopek's Avatar
It's REALLY unlikely that your '04 Lancer has a clogged fuel filter. At MOST it's been driven for about 2 years, and the amount of crap that could be clogging it is minimal.
Old Aug 8, 2005 | 02:10 PM
grubiaco's Avatar
One you remove the seat and remove the metal cover. YOu are going to have to remove the medal plating and then pull out the entire setup. Make sure you mark the metal plate so that reinstalling is expedited.
Old Aug 9, 2005 | 05:56 AM
davids2004's Avatar
Well I have tried everything else to get my gas mileage back almost. Next step is fuel injector cleaner to see if that works.
SlowCar
May 9, 2005 05:02 AM
frkypenguinboy
Lancer Troubleshooting
32
Jan 7, 2005 09:14 AM
KillaSweep
10
Nov 2, 2004 08:34 AM
Crazy4Cars
Jun 13, 2004 07:41 AM
hotfire007
Oct 8, 2003 02:41 AM
