Battery
Old Feb 2, 2006 | 09:08 AM
TougeOZ_04's Avatar
Battery
Ok so i've taking the negative off like twice now. i was in the process of taking it off again to do some mods
but the damn SCREW is striped how do i get it off noW??
should i take it to the dealership?
Old Feb 2, 2006 | 09:20 AM
gregivq's Avatar
Cut it! Replace with something stronger/better.
Old Feb 2, 2006 | 05:58 PM
Richplaydo's Avatar
Yeah I swear they use like tin or something for the battery terminal bolt. I did a decent job of stripping mine when I was installing my sound system. It still is managable, I just have to be careful. It is such a soft piece of crap tho...
Old Feb 2, 2006 | 07:18 PM
Walkingchaos's Avatar
dremel it, then just go to home depot and find a nut and bolt combo that fits and isnt made of cheap *** soft steel. Stainless or if you can find it brass.
Old Feb 2, 2006 | 07:39 PM
twardnw's Avatar
replace it with a real battery terminal, thery'e only like 3 bucks at a local auto parts place. If you want to do it right, get the kind that you have to solder the ground lead into it.
Old Feb 2, 2006 | 07:59 PM
TougeOZ_04's Avatar
how much would that cost to do the solder??
Old Feb 2, 2006 | 08:01 PM
twardnw's Avatar
probly about the same price for the terminal, then you'd need a propane torch and some solder. Heat the terminal until you can melt the solder into the connection, then shove the wire in. Let cool while still holding the wire in, so that it doesn't come back out inadvertently. (and use pliers to hold it).
Old Feb 3, 2006 | 06:44 AM
Blacksheepdj's Avatar
I'm sorry, but if you have to ask that question, have someone do it for you. Soldering an important connection isn't something for amateurs.
Old Feb 3, 2006 | 07:04 AM
Danno's Avatar
Agreed
and to add to that, if you havent learned that you are supposed to use the proper tools for the job yet, replace your terminal bolt, install it with the proper tools and chalk this up as a learning experience.
PSST. if you use wrenches rather then a pair of plyers/vicegrips/channel locks...etc. It should have never stripped in the first place.
Old Feb 4, 2006 | 08:44 AM
TougeOZ_04's Avatar
well yes i don't plan on doing it... i might just get a better battery
Old Feb 4, 2006 | 08:53 AM
twardnw's Avatar
that won't do much for the terminal
EvoTillIDie
Feb 2, 2011 10:39 AM
ballallday89
Jan 13, 2008 05:46 AM
JSYEVO
May 20, 2005 04:50 PM
batty
Nov 16, 2003 10:32 PM
lancer02Josh
Oct 17, 2002 08:53 AM
