RRM intake manifold and throttle body ?s
Old May 13, 2006 | 09:34 AM
  #91
Ozdriver's Avatar
ok thanks guys
Old May 14, 2006 | 02:13 PM
  #92
Ozdriver's Avatar
ok everything is installed..... my car is ideling at 1500 RPMs no heat on and the car is warmed up any suggestions?
Old May 14, 2006 | 05:26 PM
  #93
ROCK's Avatar
First off is idle steady? Second off AFC may not be tuned right. Not sure why you have it but check into that. Then check for vacuum leaks.
ROAD/RACE
Old May 14, 2006 | 06:50 PM
  #94
Ozdriver's Avatar
the idle is steady...... afc hasn't been tuned yet just installed on the car havent changed anything as far as A/F goes..... I'm assuming I just need to adjust something on the TB a little but I figured I would ask if anyone else had to do anything like that with theirs
Old May 14, 2006 | 08:51 PM
  #95
ROCK's Avatar
You can turn down the idle on the t.b. There is air mixture screw facing up. IT is ususaly under a rubber plug. Just turn it clockwise until idle is closer to 1000rpms.
ROAD/RACE
Old May 14, 2006 | 09:37 PM
  #96
comatose721's Avatar
ROAD/RACE
for a visual go here:
https://www.evolutionm.net/forums/sh...d.php?t=194119
Old May 15, 2006 | 09:14 AM
  #97
Ozdriver's Avatar
figured that out last night....... thanks guys...... great product ROCK
Old May 15, 2006 | 10:23 PM
  #98
ROCK's Avatar
Cool. Please get me those cores and We can start sending out the header.
ROAD/RACE
Old May 16, 2006 | 06:28 AM
  #99
Ozdriver's Avatar
sent them out yesterday
Old May 16, 2006 | 06:59 AM
  #100
ROCK's Avatar
Thanks
ROAD/RACE
Old May 16, 2006 | 12:40 PM
  #101
Ozdriver's Avatar
just figured I would let any one that may be wondering know what I have noticed .... there is no difference in the sound of the engine after I installed that I can tell (for me that was a plus) noticable gains on the highway at high rpms... it was kind of an expensive mod for what you get IMO but I think it will be worth it in the long run
Old May 17, 2006 | 07:03 AM
  #102
ROCK's Avatar
It is not TURBO but it is worth it. Thanks for the review.
ROAD/RACE
Old May 17, 2006 | 08:31 PM
  #103
Ozdriver's Avatar
ok I ment to mention this to you guys I couldent use the throttle body spacer that I bought it didn't seal the IM and TB.... I talked to accolade sports parts and they told me to contack RPW so I did and they asked me to send them a pic of the spacer and stock gasket here is a pic of the spacer and the stock gasket that I sent them ( the reason the spacer didn't seal was because it doesn't have the little tab on the left side of it like the stock gasket
now that I have sent them that pic they want a pic of the throttle body but I'm not taking my car back apart.... . if anyone could scrape up a good pic of the manifold side of the throttle body for me I would greatly appreciate it
Old May 17, 2006 | 08:38 PM
  #104
ROCK's Avatar
YEA that spacer really is not right. Lancer Manual is very specific on gasket placement. You cannot even have it flipped backwards or it will cause a problem so that spacer would cause a problem for sure.
ROAD/RACE
Old May 17, 2006 | 08:44 PM
  #105
Ozdriver's Avatar
I hope I put the gasket in right...... what happens if it were flipped backwards? wait.... there is on;y one way it can go on and line up right? cause everything lined up good so I should be ok right?
