100mph is it a computer thing
Old Aug 31, 2006 | 11:39 AM
  #61
ambystom01's Avatar
If he could accelerate to a higher speed before installing the body kit, the problem is clear. Again, I doubt any torque loss produced by the addition of an exhaust system would be significant enough to cause a dramatic lose in top speed. We are literally talking about 1-2 ft-lbs, and even then it's only during the low RPM range.
Old Aug 31, 2006 | 11:58 AM
  #62
rally-on's Avatar
Originally Posted by EvoJutsu
I luv lancers ES but lets go the point. It only has 120 hp to the crank. Unless u have major modifications, i dont think a lancer ES can even reach 110. A SRI ( yield very minimal gains), the pulley is good for about 7 hp, and exhaust will yield like another 7. There is no way a base lancer can have a high top speed unless turbo'd or major bolt-ons ( like headers, full exhaust, CAI, and etc) but still they would reach around 120.
well i was reading this when it was started monday night it was so i said i will try to go that fast 120 since i have only went 100
well i must say it got up and went to 120 no prob
bone stock right now 05 ES i am happy and like the one said in a quote it goes 90 in 4th gear so you got all 5th,,, and that is what i had left too i am addong some SRI next week and i will update on that
late
Old Aug 31, 2006 | 12:09 PM
  #63
rally-on's Avatar
Originally Posted by Offender
Have you accelerated past 6000 RPM in the stock Lancer? If so I'd like to see it.
you can not it has a rev limit
Old Aug 31, 2006 | 12:21 PM
  #64
rally-on's Avatar
piggy back
i want to get a piggy but i am worried that i will not be good with it
my concerns are
when i get it is it programed for the mods i have
how do i adjust it and is it user frindly
is it pretty much plug and play ,,i get it i take the glove box off i plug it in i turn the car on and go
,,you no stuff like that so if yiu could shed some light in the issuie that would be great guys thanks
Old Aug 31, 2006 | 12:40 PM
  #65
crypto's Avatar
Former Vendor
the rev limit is about 6200. so yes its possible. although its not much past 6000, it still past it
Old Aug 31, 2006 | 01:12 PM
  #66
Offender's Avatar
Sorry, I should have specified past 6k in 5th gear. The rev limiter is still set at 6,250 on the ECU
Old Aug 31, 2006 | 01:17 PM
  #67
Offender's Avatar
my concerns are
If you are talking about the RRM Piggyback there are slight differences in the old versions (that you could buy off someone on here or on Ebay) and the new one. RRM has threads with all the information about each one in them, just do a search.
Old Aug 31, 2006 | 01:38 PM
  #68
rally-on's Avatar
buy 1 of e bay are they any good
and what would i put as search
if u would not mind
and what about the other issues with user frindly
Old Aug 31, 2006 | 01:44 PM
  #69
Offender's Avatar
Without direct comparison Dynos for stock exhaust vs. larger aftermarket exhaust you can't make that claim. Even the amount of TQ isn't that dependant on what I'm saying, here is what I'm talking about:
Dyno results from a Lancer with an large aftermarket exhaust- notice that the PEAK TQ ends about 4,200
https://www.evolutionm.net/forums/at...chmentid=46875
Dyno results from my Lancer, with comparable mods to the car above except with stock exhaust, notice that my peak TQ ends about 4,700
https://www.evolutionm.net/forums/at...chmentid=89420
So if a cars acceleration follows the TQ curve (this is every car, every time) and you need TQ to overcome air resistance and rolling resistance then having your peak torque ending earlier in the powerband means...... lower top speed.
Old Aug 31, 2006 | 01:47 PM
  #70
ambystom01's Avatar
You have to look at one car, and notice changes that way. Comparing car to car is very difficult.
Old Aug 31, 2006 | 09:36 PM
  #71
03RallyLancer's Avatar
i never said i could go past 6000 rpms... however like i said according to your reasoning i should be shifting at 4200k rpms b/c after that tq drops and i cant accelerate anymore. an exhaust again will only lose lowend tq.... and again last time i checked you dont go 100 in 2k in 5th gear so he loss from the exhaust should not limit his top speed.
and where did you get those graphs from? it looks like a 5 year old made the second one, not to mention ive not seen anyone crank out that much hp NA like in the first...
edit: **** my old *** nissan stanza beater can do 100 and its got maybe 90hp and maybe 90tq to the wheels
Old Sep 1, 2006 | 06:38 AM
  #72
Blacksheepdj's Avatar
We've gotten too far away from the original topic.
If you'd like to continue the various discussion points, start threads for them.
Charlie-Y
Jul 23, 2011 01:24 AM
05mazdarx8
13
Dec 17, 2008 06:15 PM
Jon91TSi
Nov 4, 2007 05:46 AM
ozrally0303
Aug 28, 2006 04:28 PM
TG LanceR
Lancer Troubleshooting
24
Mar 16, 2004 02:01 PM
