Old News!! 4G64 Swapped Into A 2002 Lancer
Old Aug 1, 2009 | 04:54 PM
  #541
imalancerman's Avatar
The crankshaft position sensor very well could, let me guess, its cranking but wont start right?
Old Aug 2, 2009 | 06:52 AM
  #542
darkmitsu's Avatar
yep there is cranking but no start...
Old Aug 5, 2009 | 11:33 AM
  #543
senate6268's Avatar
Does the 4G64 crank position sensor send the same signal as the 4G94 one does? Also, are you still running the 4G64 ECU? The Evo immobilizer disable code does not work for the 4G64 ECU. You run the risk of damaging the ROM by flashing it on there.
As I have said before, to the best of my knowledge, nobody has been unable to disassemble the periphery bits for the 4G64 ROM to disable the immobilizer. As such, you will not be able to start your car. It will crank, but not start - the same as you are experiencing. Your best bet is to use the Evo ECU and disable the immobilizer bits.
Old Aug 16, 2009 | 07:10 PM
  #544
darkmitsu's Avatar
Ok current updates, I have decided there is not enough help / technical resource in the 3g eclipse world , and 1 out of every 250 people on all the 3g forums I joined knew anything about performance , and the ones that did werent willing to share there information...
I went ahead and got a lancer evolution ecu and swapped it in, using senates how to so the imobilizer issue is solved , and since the there is a few people already running the evo ecu in there eclipses this should be a bolt and go affair.
I have begun cleaning/disassembling the motor and tranny , and the plans are to use the factory lancer harness , with the lancer evo ecu ....
Old Aug 16, 2009 | 07:36 PM
  #545
Keep us updated, im wanting to do this in the future.
Old Aug 17, 2009 | 11:37 AM
  #546
cedes14bamg's Avatar
there finally read it all within hours !! god that sure was alot of reading, i call this worst then school hahah
(Y) but yeah this the very best thing to do to a lancer
so me too!
Old Aug 18, 2009 | 11:15 AM
  #547
Jehuty's Avatar
keep the updates, take some photos, do it as you go. Most people tend to say i'll post photos when it's ALL done. Don't do that because you'll disappear and we'll never hear from you again.
Old Aug 21, 2009 | 11:41 PM
  #548
rpm_ruffryders's Avatar
Originally Posted by Jehuty
where do you stand with doing this over again?
just waiting on the other guys insurance to write that check. but I am STILL looking for a shell. I got all the mechanical parts sourced out...so I KNOW where to go...I JUST NEED A SHELL AND MONEY! lol
but I say, HOPEFULLY a good Christmas present for myself. HOPEFULLY...
Old Aug 22, 2009 | 06:17 AM
  #549
Jehuty's Avatar
You need to get on AIM so that we can talk about this, I have a friend who could probably do this for himself.
Old Aug 26, 2009 | 06:35 PM
  #550
darkmitsu's Avatar
well current update... Tonight pulled the motor in record time for me , took 4 hours... more to come soon , everything is sitting in the garage will be dropped in , in the next couple days...btw does anyone need a stock motor (4g94) with about 16-18k miles on it , it came out of an 06 I put it in my car in january this year , I also have a stock(4g94) boss clutch with 10k miles on it , and a transmission with 130k on it...
Old Aug 27, 2009 | 06:41 AM
  #551
Jehuty's Avatar
Depending on what happens here...will help me make a decision for my car. I wish I could take your engine, but you live TOO far!
Old Aug 27, 2009 | 06:52 AM
  #552
Jehuty's Avatar
Also, are you manual or are you automatic?
Old Aug 27, 2009 | 06:17 PM
  #553
darkmitsu's Avatar
i am manual, I went out tonight and turn some more wrenches... Ill have more to come soon I took some pictures, senate I need to know about the axle research you were doing I found out the eclipse driver side is definately to long the passenger side fits quite well although it is about 1/2inch to an inch longer than the lancer axel I wonder if thats going to cause a problem when its on its own weight on the ground... I made a hybrid axel using the lancer shaft and the inner eclipse hub but I dont really want to use it...
Old Aug 27, 2009 | 06:23 PM
  #554
darkmitsu's Avatar
Originally Posted by senate6268
Yea, I didn't think the Evo ROM would work on a 4G64 ECU. I'm almost 100% sure the memory is different between the Evo ECU and 4G64/4G94 ECU. Renesis is the company that makes the chips in Mitsu ECUs. Different chips have different ROM and RAM sizes and memory addresses.
I'll save you the time on diciphering the other 50% of the harness... it's the same as the Lancer.
Onto a more serious note, I've come with with a solution to use the 4G64 tranny in the swap without swapping the internals from the Lancer trans. Well, half of a solution really. Here's what I got so far:
The main difference between the 4G64 and 4G94 transmissions is the differential. The 4G64 and 4G69 transmissions use the same differential. The 4G69 and 4G94 axles use the same outer CV. This is evident in that the front spindles are the exact same (see my thread on 5-lug conversion: https://www.evolutionm.net/forums/la...part-list.html).
See where I'm going with this? The 4G69 driverside axle has the same inner CV as the 4G64, the same outer CV as the 4G94 and the same axle length as the 4G94. Long story short - Ralliart driverside axle is a direct swap to use the 4G64 transmission.
As far as the passenger side, I'm still working it out. Easiest route might be to simply pick up another Ralliart driverside inner CV and swap it out on the Lancer passenger side axle. I'm still working on comparing parts/diagrams in the Mitsu parts catalog to see if this is a go or not.
I'm sure this info would be more than valued on the build how-to on page 1.
Thank you senate you are a god I will be buying a set of these tommorow... what year ralliart do i need to get them from?
Old Aug 27, 2009 | 07:10 PM
  #555
Jehuty's Avatar
I hate being frikin automatic. I wish it was easy to do the manual swap, but there are NO junked lancers near me.
