ROAD/RACE- Pulley 2008 Lancer
Old Nov 8, 2007 | 02:19 PM
  #316
elpoole's Avatar
Obvious, yes. But knowing how far would tell you if you were going in the right direction, its a gauge to know if your pushing hard enough, in the right direction, takes the guess work out, especially when the parts company is aware that alot of individuals will be attempting this installation laying under their car with 3000lbs above them possible using the OEM jack. Its "obvious" that many a newb will be attempting this. It would suck for someone to be pushing like hell in the wrong direction and possible rock it off the jack stand. For the simple fact that anyone even had to reply to this post is testimate that a little more time on the install diagram and directions would save a ton of time later. Time that could be spent developing a profitable, in very high demand item like a Turbo!
Distance and Direction are requirements for accurate installations and how tos related to mechanical schematics. Having that information on the diagram would have solved quite a few questions you see on the eboards.
By the way, Im using a 2 ton jack, jack stands and wheel chocks, as everyone should.
I appreciate the help everyone. Im sure from here I can get it on. Thank you Rob.
Looking forward to the Turbo!
Old Nov 8, 2007 | 02:37 PM
  #317
nj_08_gts's Avatar
Point taken. But do remember that RRM (and many other companies) may not bank on noobs installing parts like this, so some points on the instructions are glazed over and assume prior knowledge. And while clearer instructions may have prevented a lot of your posts, in the end, the thread is what saved your *** (and maybe somebody else's too)...even if the instructions were flawless there would be questions. NOBODY never has questions...things always come up that the instructions won't prepare you for. As an aside: If somebody is crawling under the car using the OEM jackstand...Darwin needs a word with you.
Old Nov 8, 2007 | 02:50 PM
  #318
elpoole's Avatar
Darwin needs to help with the Turbo!
Thanks again for the help. Peace
Old Nov 8, 2007 | 09:48 PM
  #319
ROCK's Avatar
We really do try and listen to feedback on directions and try to incorporate it. Question now is CLOCKWISE or COUNTER-CLOCKWISE? I actually heard 2 different versions myself today. I just want to fix that part of the directions. Please post one word answer to my question so I can put it to bed.
ROAD/RACE
Old Nov 9, 2007 | 02:53 AM
  #320
FinestSoldier's Avatar
Counter-Clock wise.
Old Nov 9, 2007 | 05:49 AM
  #321
SamT83's Avatar
Push the wrench up and to your right if you're under the car and you slid under head first on the passenger side. I know that's not one word, but that's about as specific as it can get I think. The tensioner should move a half inch or an inch or something towards you and the belt will immediately loosen. When I installed it, it was the first time I had done anything like this and it took me awhile to finally get it on, but once I did it was like, "Well hell, that was easier than I made it out to be." Apparently I'm lucky to be alive too, cuz I only used the jack stand in the trunk and had no one helping me with the tensioner part. Haha. I'm just gonna chalk that up to being the man and, looking at it that way, it makes sense. Ha, anyway, the tensioner part does take some strength, but I did it myself with a normal sized wrench, so stick with it if it gets a little frustrating.
Old Nov 11, 2007 | 09:13 AM
  #322
nj_08_gts's Avatar
Originally Posted by SamT83
...stick with it if it gets a little frustrating.
Good attitude...and probably the best way to learn about cars
Old Nov 12, 2007 | 01:31 PM
  #323
ROCK's Avatar
Attitude is everything!
ROAD/RACE
Old Nov 16, 2007 | 10:33 AM
  #324
WhiteGTS18's Avatar
just put on my pully last night and I must agree that it is a pain. getting the tension off the belt is easy and with an impact, getting the pully off and on is a snap. but when you go to put the belt back on yourself be prepared for a fun time. I did it after a while but its a pain in the butt pulling on the wrench and slipping the belt on at the same time without killing your hands. as for value you cannot beat it, you can deffinately feel it and notice it rev easier.
Old Nov 16, 2007 | 01:12 PM
  #325
ROCK's Avatar
Guess that means it is worth the pain. Lets say... You are a better person for doing it.
ROAD/RACE
Old Nov 16, 2007 | 01:53 PM
  #326
krnkimchi702's Avatar
for your hard work.. lol
Old Nov 17, 2007 | 10:49 AM
  #327
I noticed since i installed the pully when ever i have the music blasting, if i give it throttle or press the brakes i can hear static from the speakers "not radio type static" like really high tone static good example is when you get shocked by the metal of our cars that sound. man i have no luck with aftermarket. i find all teh bad stuff
Old Nov 17, 2007 | 05:34 PM
  #328
nj_08_gts's Avatar
Motors can create EMI, so it not impossible that a high-revving engine will give you some static (just very unlikely). Do you have after-market speakers? If so, you may want to go with a higher quality brand.
Old Nov 18, 2007 | 06:09 AM
  #329
i have the stock premium fosgate system. It never did that before.
Old Dec 19, 2007 | 02:17 PM
  #330
so im planning to buy the pully... just checkin up and seeing if everyone who has bought one is satisfied with their purchase?
