ROAD/RACE - 4B11 Header
Old May 31, 2008 | 12:27 PM
  #496
djslik408's Avatar
Just curious what the ETA is on the Cell Eliminator. Thanks.
Old Jun 1, 2008 | 07:22 PM
  #497
ROCK's Avatar
I think I posted. THis week we will finish R & D on it. After that it will not be long.
ROAD/RACE
Old Jun 1, 2008 | 09:06 PM
  #498
m20racer's Avatar
^ don't you think if the header was designed right in the first place you would not need the stupid CEL Eliminator and having to rent a car for a doner car.
Old Jun 1, 2008 | 10:01 PM
  #499
ROCK's Avatar
You misunderstand. We need to rent a car for the guy who has done all the R&D. Our shop cars are FEDs his is PZEV. As for design of the header, It is fine, maybe you don't understand why the CEL even comes on. There is a reason related to the cat....... Ther is no way around it and ANY HEADER, ANY HEADER for 08 PZEV would require something to eliminate this issue.
ROAD/RACE
Old Jun 2, 2008 | 10:42 PM
  #500
ROCK's Avatar
Header is selling off the shelf meantime. Going to be used on UTCC Race Car along with piggy and pulley. More on that soon.
ROAD/RACE
Old Jun 11, 2008 | 04:52 PM
  #501
ROCK's Avatar
CEL eliminators are being made as we speak. In 2 weeks we will have 25 units. They will still be sold separately for PZEV header guys. We have good instructions for it too. Remember this will be an electronic device in case you didn't know that.
ROAD/RACE
Old Jun 11, 2008 | 04:58 PM
  #502
mines hotter's Avatar
how does the cel eliminator work and will it be difficult to install
Old Jun 11, 2008 | 09:38 PM
  #503
cRc`22's Avatar
u just screw it into the o2 sensor hole i believe.. and it shoots some type of voltage or some such to make the car think its fine..
Old Jun 11, 2008 | 11:28 PM
  #504
LuDa's Avatar
doe sthat mean if you car has any other problem that would trigger the CEL that the eliminator would make the car ignore that also?
Old Jun 12, 2008 | 07:54 AM
  #505
aftermarket's Avatar
ROAD/RACE
So Rob, let me get this straight.
If you have a FED car (I'm in Canada), I won't need a CEL eliminator and I wont have problems with engine lights going off with the new header installed???
Thanks!
Old Jun 12, 2008 | 08:07 AM
  #506
SamT83's Avatar
Thanks!
That's right.
Old Jun 12, 2008 | 12:43 PM
  #507
EngRWW33's Avatar
what is the price going to be on this eliminator?
Old Jun 12, 2008 | 12:45 PM
  #508
Originally Posted by SamT83
That's right.
Woohoo!!!!!
Will be placing an order for one then by the weekend!
Old Jun 12, 2008 | 06:42 PM
  #509
dejesus360's Avatar
12 June 08 - I just installed the PZEV header on my 08 GTS. I did not see a CEL come on. Is this something that'll happen later? Or is it supposed to happen right away? I made sure that all the torque specs were right. I installed the old sensor in the hole provided and connected it again. Have I done something wrong or do you think it is the other aftermarket stuff i have on the car?
13 June 08 - OK, update... The CEL just came on this morning. I guess it takes a while before the ECU figures out there's no cat. I didn't unplug the battery for 15 minutes to allow the ECU to reset. I need to remember that when I do $#!^ like this. A rookie mistake...
Old Jun 12, 2008 | 09:24 PM
  #510
ROCK's Avatar
FED cars DO NOT NEED A CEL ELIMINATOR. Just the pzevs will need it even though lots of guys are running them currently on pzevs and could care less about the light.
ROAD/RACE
