Pulley and oil leak - both stock and RRM *IMPORTANT*
Old Jan 23, 2011 | 10:21 PM
  #91
ROCK's Avatar
Originally Posted by pcguru2000
Yup, same here. Have it on two cars, no oil leaks. I've also been running the sri on both cars for the same amount of time, no problems there either.
Thanks for the post. These things are out there in the 1000s with issues in single digits 1-9! Rock Solid parts (no pun) for your Lancer.
ROAD/RACE
Old Feb 13, 2011 | 03:20 PM
  #92
mrbloink's Avatar
Has mitsu solved this problem in the 2010 lance de? I'm getting the rrm one in a couple weeks anyway but I was just wondering. Ill post a pic when I take mine off
Old Feb 13, 2011 | 04:47 PM
  #93
ROCK's Avatar
Everything is long solved now. Problem only occurred on 2008s. They fixed that seal a long time ago. 2010 surely have no problem. By the way if you have a DE you MUST GET A REAR SWAYBAR FROM US. IT is almost a matter of safety the car sways so ****en hard.
ROAD/RACE
Old Feb 15, 2011 | 03:18 PM
  #94
mrbloink's Avatar
I was going to get the works one because they have the mounting hardware and your site says its just for the es and the gts. If you guys have the hardware also then I'd much rather order it from you all together.
Old Feb 15, 2011 | 06:29 PM
  #95
ROCK's Avatar
We have everything you need to install it! AND YES it FITS tot 2010 and 11. Thanks We have it in stock and will ship the same day you order. Thanks.
ROAD/RACE
Old Feb 20, 2011 | 06:54 AM
  #96
mrbloink's Avatar
I am about to order the sri, crank pulley, grip springs, rear sway bar and front tie bar. I just had a quick question before i order. Will all of these parts fit the 2010 de? I just wanted to make sure that if i order all of these parts that there is nothing additional that I will need since the sway bar says its only for the es and gts. should I leave in the special notes section that I have the de?
Old Feb 20, 2011 | 07:18 AM
  #97
M@verik's Avatar
Yeah I believe the sway bar wont fit the DE as the DE has no sway bar stock. U will need a little more work to fit it correctly. Otherwise everything else should be fine.
Old Jun 21, 2011 | 10:46 AM
  #98
pcguru2000's Avatar
I've got a 09 DE and put rrm's strut tower and sway bar on. The SRI fits well also. My pulley is NOT leaking oil either and it was installed a month after I got the car. Testimony to good workmanship.
Old Dec 23, 2011 | 10:53 AM
  #99
Evolve247's Avatar
Almost 4 full years with the first-version pulley. No leaks. No problems.
Old Dec 25, 2011 | 01:46 PM
  #100
ROCK's Avatar
That leak happened to George Bush Edition pulley, all of 2 times. This thread can be deleted at this point. Any mods listening?
ROAD/RACE
Old Dec 25, 2011 | 07:44 PM
  #101
Myszkewicz's Avatar
I don't want to delete this, but I have un-stickied it. It'll fall off the page soon enough.
Old Dec 27, 2011 | 09:15 AM
  #102
ROCK's Avatar
Makes sense to un sticky it for sure. Thnx
ROAD/RACE
Old Dec 27, 2011 | 11:58 AM
  #103
Evolve247's Avatar
Rob, i'd be against deleting the thread too because any curious reader will see how the thread progressed and who consistently has no issues with the pulley.
Old Dec 29, 2011 | 05:49 PM
  #104
Hiboost's Avatar
Pulley works great on the Outlander Sport SE I have, no extra vibration or noises so far. Sorry for bumping the tread again! LOL
AlisterMcRae
Jul 3, 2019 09:38 PM
mugen777
67
Aug 8, 2015 03:31 AM
cdupont03
For Sale - Part Outs
39
Dec 17, 2014 03:19 PM
toxic-evo
For Sale - Cars For Sale
11
Mar 17, 2013 05:02 PM
alan678
May 14, 2010 10:27 AM
