RPW Stage 1 camshaft installed w/ write up.
Old Dec 13, 2005 | 09:50 PM
  #76
03RallyLancer's Avatar
if you are seriously thinking n/a you might want to look into something that can adjust timing and not just a/f
Old Dec 13, 2005 | 09:54 PM
  #77
twisty1251's Avatar
i was thinking of installing a turbo cam, then saving for boost.
Old Dec 13, 2005 | 09:57 PM
  #78
then you are most definatly gonna want something that can retard the timing so you can get the most out of your turbo and cam combo
Old Dec 13, 2005 | 10:28 PM
  #79
GreenPsycho's Avatar
DING! yeah, most definately you'll need something to adjust for timing, although you can do that to some extent with the camshaft gear. Dunno, but i would look into it a bit deeper before you start shelling out money
Old Dec 14, 2005 | 09:12 AM
  #80
comatose721's Avatar
the adjustable gear offers a fair amount of play with the timing but not even close to the ability that a controler would do (or stand alone).
Old Dec 16, 2005 | 10:52 PM
  #81
KillahB's Avatar
Whoa!! You guys are talking and confusing (or so it seems) ignition timing and camshaft timing.
Old Dec 17, 2005 | 06:25 AM
  #82
gregivq's Avatar
+1
I didn't want to say anything because some of the posts are very vague (post #79).
Cam gear = camshaft timing
Emanage, EMS = spark plug timing
Cam gear is used to retard/advance camshaft timing. If I remember correctly,
if your highest HP is at 5k rpm then after advancing the 'camshaft' timing that point will happen earlier.
Old Dec 17, 2005 | 07:46 AM
  #83
i just don't like typing. i'm already typing up my novel so i am as minimal as possible in my words and just hope that people understand what i'm getting at until a detailed description is required
i just didn't feel like specifing when the topic shifted from ignition/idles to camshaft timing.
drucea
Oct 2, 2017 08:26 AM
4g94T
Lancer Engine Tech
53
May 30, 2010 01:38 AM
ambystom01
Jan 20, 2008 01:35 PM
newbiewonkenobe
Lancer Engine Tech
Jun 1, 2006 07:12 PM
WADADLIG_OZ
Lancer Engine Tech
52
Nov 11, 2005 04:57 AM
