OK-Piston removal-pics!!
Old Nov 11, 2003 | 08:10 PM
agent5568's Avatar
Piston removal-Parts back from machine shop!-pics!!
I started teaing into the motor last night.
Old Nov 11, 2003 | 08:12 PM
agent5568's Avatar
Piston removal! Parts back from machine shop!PICS!
valve cover off.
Old Nov 11, 2003 | 08:15 PM
agent5568's Avatar
after getting everything loose last night. I waited until daylight to finish getting everything ready to pull the head off. I drained all the fluids. lol
Old Nov 11, 2003 | 08:17 PM
agent5568's Avatar
unbolted the test pipe so I could get the manifold off, and move it out off the way.
agent5568's Avatar
the manifold off and out of the way.
Old Nov 11, 2003 | 08:19 PM
agent5568's Avatar
Iff you look real close you can see traces of piston. Taking the head in the morning to see if its ok.
Old Nov 11, 2003 | 08:21 PM
agent5568's Avatar
At this point everthings off including the oil pan- which buy the way was a pain in the ***.
Old Nov 11, 2003 | 08:22 PM
agent5568's Avatar
This is what i found in cyl. #2 #3 #4- small pieces of melted metal.
Old Nov 11, 2003 | 08:26 PM
agent5568's Avatar
All of the pistons except for #2 are fine- The top side was blown off on # 2 all of the following pics are of the same piston. I was running a 55 shot Zex Kit. I will post the pics of the install in a few days. I am going to take the head to the machine shop in the morning. Put the new pistons on the rods, gap the rings. And put it back together. I might even put the turbo kit on. Depends on the cash.
Old Nov 11, 2003 | 08:27 PM
agent5568's Avatar
same piston.
Old Nov 11, 2003 | 08:28 PM
agent5568's Avatar
Same piston #2
Old Nov 11, 2003 | 08:30 PM
agent5568's Avatar
Last pic- iwill show pics of the install. in a few days.
Old Nov 11, 2003 | 08:31 PM
bobaab's Avatar
that's a nice crack there..are you going forged piston and piston rod now?
Old Nov 11, 2003 | 08:33 PM
tenkawa_akito's Avatar
and this is why we don't play with nitrous j/k
50 shot was supposed to be the safe limit on stock internals, right? are you going to upgrade to some forged parts or replace with stock?
Old Nov 11, 2003 | 08:34 PM
agent5568's Avatar
I am going with the JE pistons from Road race
